  • July 15, 2025, 12:23:50 AM
Author Topic: Aerotiger .36 Tank size  (Read 1662 times)
Offline mike londke
« on: August 11, 2020, 08:39:13 PM »
I should have asked this in the other post on the PA 40 but how much fuel will an Aerotiger 36 need for a pattern? Thinking about a Vector 40 ARF for Sam. Thx
Re: Aerotiger .36 Tank size
« Reply #1 on: August 16, 2020, 10:18:58 PM »
Happens that I asked that question before, perhaps by PM. Ty Marcucci said 4.25 oz was enough, but as always, it's easier to put less in than the maximum. Brett wrote here that the way to get a consistent amount in the tank is to fill it and then take out some, using a smaller syringe than folks use for filling (smaller diameter = more accurate).
Personally, I use a "mustard pump"  (they'll blow up a combat bladder), and at least the ones I've gotten from TAP Plastics pump EXACTLY 1 oz per full stroke...but you do have to "prime the pump" at the start of each flying session. I made up a double loop thingy from coat hangar wire to hang the 1 oz syringe from the pump/jug, which I use to pull out excess fuel.
I am fussy about keeping my fuel clean, and really cringe to see guys open a gallon jug, suck some fuel into their 5 oz syringe, and lay it in the grass or on the pavement. A lot of those guys have changed to using electrons....   LL~ Steve
Offline Alan Buck
« Reply #2 on: August 17, 2020, 06:19:37 PM »
Mike  at the nats my aero/tiger 4.5ozs for pattern  10nitro 18 oil
ALAN E BUCK
« Reply #3 on: August 31, 2020, 12:03:13 AM »
Ball bearing engine and likely running at higher rpm!   y1 Steve
Offline mike londke
« Reply #4 on: September 08, 2020, 07:26:15 PM »
ARF Vector on the way. Aerotiger .36 it will be. Thanks.
« Reply #5 on: September 08, 2020, 09:06:11 PM »
Mike  put a  4.5 ounce  uniflow tank in it, That should  be enough as  most people  use  from 4  to  4.5  ounces
Offline mike londke
« Reply #6 on: September 09, 2020, 09:10:03 PM »
Will do.
