  • June 20, 2025, 05:01:33 AM
Author Topic: new nva on an old engine.  (Read 1643 times)
Offline Perry Rose
« on: October 07, 2016, 11:50:37 AM »
Again. the OS remote nva from the LA series engines bolts right on the McCoy .35.
Offline Perry Rose
Re: new nva on an old engine.
« Reply #1 on: October 07, 2016, 11:55:08 AM »
Can't fit both pictures on the same post. It will take some minor trimming of the bracket and lots of plastic washers to install it on a Fox .35.
Offline Allen Eshleman
« Reply #2 on: November 15, 2016, 04:21:05 PM »
How well does it run?   Have you tried it in flight yet?  Very interesting.  Those McCoy needle valves are hard to find.
Offline Allan Perret
  • Proverbs
« Reply #3 on: November 15, 2016, 05:41:55 PM »
Thanks for the tip Perry.  I'm getting ready to put a MC35RedHead on a ringmaster.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #4 on: November 18, 2016, 08:11:14 PM »
I've had several of the metal needle valve plates break from fatigue fractures.  A piece of 1/16in. nylon sheet or even a cut down control horn does the same job and only sometimes breaks in a crash.
