  • June 20, 2025, 07:12:01 PM
Author Topic: Magnum XLS vs. OS FX?  (Read 1077 times)
Offline Harleyman
  • ACE
    • Circle Masters
« on: March 20, 2007, 01:48:20 PM »
The Magnum XLS series engines seem to be very similar to the OS FX engines. Do any of you have any experience with the two types side by side?
Many have noted that the Magnum XLS 36A is a fine motor that provides a good Stunt run.
Doesn't Mr. PTG run a 36 Magnum in his Divas with good results?
Can the OS FX motors can be set up the same?  Do any of you engine guys know?
Chris Sterner
AMA 1825
EAA 1429853
https://circlemasters.com
