  • June 24, 2025, 10:53:52 AM
Author Topic: Adjustable engine mounts?  (Read 1133 times)
Offline phil myers
« on: September 09, 2009, 01:35:50 AM »
Is there a proven way of fitting adjustable engine mounts so that different engines can be installed after experimenting? I plan to build the Super Clown over the winter using the ASP .15 first. If thats not enough power then I'd like to  put in the ASP .21 The .15 is 2.3 oz lighter (5.82oz) and it seems like a pretty powerful motor to do the job.  Thanks for any comments ...Phil
Offline Bootlegger
Re: Adjustable engine mounts?
« Reply #1 on: September 09, 2009, 04:38:16 AM »
  P T G suggested to me use some 3/16"x3/8" 6061-T6 alum that can be bolted to the fuse, then drill and tap the alum for the engine size that you want to try, if that engine doesn't work make another set of alum mounts, that will bolt into the original mounts, drill and tap mounts and install new engine...
  Hope that this helps.......... :!
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #2 on: September 09, 2009, 05:18:12 AM »
You have a couple options. Brodak sells a clamp mount kit..
http://www.brodak.com/shop_productdetail.php?ProductID=6629
I use hardware store 1.5 - 2 inch X 1/8 aluminum and cut it in strips on my band saw. Drill the ends for the fuselage mounting bolts then drill and counter sink the back for the engine. Use 4-40 counter sunk screws with lock nuts to mount the engine. This way you are not depending on aluminum threads to hold the engine and you can use thinner more easily obtained stock.
Alan Hahn
« Reply #3 on: September 09, 2009, 07:03:22 AM »
I fly a Flite Streak with a Fox15BB (on 0.012" 52 foot lines). I am guessing your ASP will probably work fine.
Offline Ward Van Duzer
« Reply #4 on: September 09, 2009, 09:19:38 AM »
I hear Windy sells some excellent adjustables. On the other hand I've heard Brodak's are soft! Just hearsay, your milage...
W
Offline phil myers
« Reply #5 on: September 09, 2009, 04:57:36 PM »
 H^^ Thanks again for the plethora of knowledge and wisdom that cascades like a water fall through the pages of S.H.!..... I've learnt so much from you guys and even if my problems may appear to be elementery you guys are always willing to help a newbie. I really appreciate the advice....THANKYOU!! Phil
Offline Bob Reeves
« Reply #6 on: September 10, 2009, 10:25:49 AM »
W
The ones that come with the ARF's are less than optimum but do work more or less, the ones Brodak sells separate are the exact same as what Windy has.
« Reply #7 on: September 10, 2009, 10:48:50 AM »
If you use these types of mounts , use some blue locktight on them, or any good removable  thread locker
Offline Dalton Hammett
« Reply #8 on: September 10, 2009, 11:41:26 AM »
   For what it's worth,  I am using the Brodak mounts currently with an ASP .32 and a DS .40.   They seem to work fine as long as I check the bolts fairly often.
Dalton H.
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
