  • June 19, 2025, 10:19:31 PM
Author Topic: Adding shims and engine instability  (Read 3905 times)
Offline Matt Piatkowski
« on: April 10, 2017, 12:21:25 PM »
Hello,
This is continuation of work that began last year.
I know that adding shims "softens" the engines but how much shimming is too much?
Is there any general rule of "shimming"?
My Evo60NX R/C (Evolution PN EVOE0600) will only run well in 2 cycle because of the porting geometry and timing.
It runs stable 2 cycle at 10,300 launch RPM on 13x4 MAS two blade propeller, using 10% nitro Omega with some castor added.
Unfortunately this gives the lap times 4.8-4.9 seconds.
I have tried to slow this engine down and it can go into unstable 2-4-2 (fluctuating between 8,300-9,800 RPM )when the fuel mixture is rich.
Then, I have tried to add shims hoping to deal with this instability but it only made everything worse.
Any suggestions?
Matt
Re: Adding shims and engine instability
« Reply #1 on: April 10, 2017, 12:36:53 PM »
What are you shimming?
Maybe you need to de-pitch the prop?
edit: Head shims?  I'm not sure that's going to get you where you want to go.  Find one of Brett Buck's diatribes on trying to make a powerful engine into a wimpy one.  There's nothing wrong with a nice stable wet 2-stroke, as long as you can get the aircraft speed down.
« Last Edit: April 10, 2017, 05:38:32 PM by Tim Wescott »
« Reply #2 on: April 10, 2017, 03:59:27 PM »
Different prop and/or longer lines, if you're not maxed yet on line length. MAS are crappy props, as were Zingers. APC makes a 13-4W and 14-4W wide blade, one of which might work much better. Also look at XOAR, Vess, and some of the other new brands of wood props. I think most are made by XOAR in China.  D>K Steve
Online pmackenzie
  • Pat MacKenzie
« Reply #3 on: April 10, 2017, 07:25:52 PM »
FWIW if the run is good but just too fast I would try a smaller venturi.
What are you running now, since you say it was an R/C engine?
Did you buy the EVO part for the C/L version?  There are two of them, 5mm and 4.6mm
http://www.evolutionengines.com/Products/RelatedParts.aspx?ProdID=EVOE0605&Category=Parts+Listing&SubCategory=
Could also be that the C/L one has different timing than the R/C.
If you look at the pictures of the two liners the C/L one does look like they are timed less. :)
C/L liner
http://www.evolutionengines.com/Products/Default.aspx?ProdID=EVO060203L
R/C liner
Pat MacKenzie
MAAC 8177
« Reply #4 on: April 10, 2017, 08:01:01 PM »
Hello,
   I am not at all surprised at all that it made it more unstable to lower the compression. A lot of "stunt lore" (i.e. bullsh*t) has grown up around adding head shims. It's rarely necessary, and usually only small changes are required. Adding head shims reduces the power difference between 4 and 2, and reduces the power overall, and causes the 4-2 switch to take longer. The only engine I ever found to need, very occasionally, a bit mroe clearance (like .003-.005) just to work was the ST46. In that case, it was because the stock head gasket compressed over time and reduced it from what it started.
     Unless it is backfiring, quitting, etc, the compression is not too high. The fact that lowering it made it worse is pretty definitive.
    Patient, probably Misty Rowe: "Doctor, doctor, it hurts when I do this"
    Doctor Archie Campbell from Hee-Haw: "Then don't do that!"
     I am also extremely skeptical about the "timing and port geometry" causing it to only 2-stroke. But putting that aside, it sounds to me to be a combination of too much venturi and incorrect prop. You have to get off the Zinger/Master Airscrew train, at least to get it to work at all. APC 12.25-3.75 would be a good starting point.
 Put the head clearance back to what it came with and leave it alone. Reduce the venturi diameter by maybe .010" at a time, trying it after each change, until you get about the right speed AND are running right around the 4-2 break point in level flight. Then, adjust up and down from there to get the right combination.
     If you have no idea where to start, try a venturi with a choke area of about 0.018 square inches. That's about .152" for a flush outlet venturi (like the stock PA or Tee Dee 049), or .271 for a "cross the inlet" venturi with a ST spraybar. This is probably on the small side, so if you start there, run it up, not down.
« Reply #5 on: April 11, 2017, 04:39:08 AM »
Hi Tim, Steve, Pat and Brett,
I will remove the added head shims and run the engine with APC 12.25x3.75.
The venturi is custom made - see the attached. ST60 NVA is installed at the venturi choke area. The diameter of this area is 0.285" now.
My starting point to select 0.285" diameter for the "cross the inlet" venturi was the graph (attached).
As suggested by Brett, I will shim the venturi choke area to get 0.271" and run the tests.
Additional problem: ST60 NVA needle keep turning due to vibrations. Tightening the NVA brass nut works for a short time and the connection is getting loose again.
How to fix this annoying thing? There is no point to test in the air if I do not know if the needle holds the position. By the way: the vibrations are "normal vibrations to be expected" not the excessive vibrations caused by the propeller and spinner imbalance. MAS 13x4 and the spinner were balanced before tests.
M
« Reply #6 on: April 11, 2017, 10:16:55 AM »
         I can only imagine that the brass in the NVA is still creeping a bit. You need to tighten the collet until you can barely turn it, and after a few cycles, it should settle in and work OK. It needs to be that tight to obviate the effects of the needle valve ringing like a tuning fork. All bets are off if it is a "clone" version, some of those just don't work at all, and the collet bottoms out on the spraybar without really compressing it.
« Reply #7 on: April 11, 2017, 11:48:58 AM »
Piling layers of pantyhose over the venturi is a very easy way to effectively reduce the diameter, if you don't want to make a series of parts to experiment with.
Offline Fredvon4
  • Central Texas
« Reply #8 on: April 11, 2017, 12:02:50 PM »
I always defeat the spring NVAs and on PA versions I shorten them as much as practical without beating my knuckles to death to adjust
Fred von Gortler IV
Offline Lauri Malila
« Reply #9 on: April 14, 2017, 12:39:28 PM »
One thing to remember is to avoid screwing the needle all the way to bottom, it tends to wear a groove to the needle cone and that causes inconsistensies in needling. I haven't used other than PA valves for ages, so I don't know how common the issue is with other needles. But I have a feeling that softer stainless needles wear more easily.
It's easy to fix in lathe, using a small lapping stone & oil.
Regarding the original subject, shims and running stability, people ofter forget that there are 2 things in head setup that should both be optimised; squish clearance AND head volume. Just adding shims under a head with squish band  to increase volume will screw up the squish action. It plays a big part in running stability.  L
« Reply #10 on: April 15, 2017, 06:24:58 PM »
Field report: April 14, 2017.
Two flights still on MAS 13x4.
Launch RPM stable 8,500 in wet 2 cycle mode with venturi's choke area diameter decreased to 0.265".
EVO60 had still 0.51 mm. head shims in it.
Normal and inverted flight RPM were the same. When flying up and down the RPM are roughly the same.
Lap times: 5.6-5.8 sec. and this is too much on 61' long lines (eye-to eye)
Could not finish some maneuvers because lines were going slack.
Next step: launch RPM 9,000-9,500 in full 2 cycle mode to provide proper lines tension and the lap times around 5.2 sec.
Additional problem: when the model is flying normal level flight the outside wing's tip is down about 1.25". When it is flying inverted the outside wing's tip is up 1.25".
The wings are straight according to the measurements taken today. The flaps are straight. When I hanged the model using the leadouts, the wings follow the line perpendicular to the ground.
I will add tabs to the wings ends to compensate the aerodynamic moment but, having the above in mind, I have no idea where this moment is coming from.
Any suggestions?
M
Offline Chris Brainard
« Reply #11 on: April 15, 2017, 08:08:21 PM »
How much castor did you add? What is the percentage of oil, both synthetic and castor? The Evolution engines have fairly high compression ratios and when you add more oil, it raises it further. Adding shims to lower the compression ratio raises the head which screws up the ignition timing. My Evolution engines run best on straight Cool Power 10% nitro and 18% all synthetic oil. No head shims, no extra castor oil and low pitch APC props.
Chris Brainard
« Reply #12 on: April 15, 2017, 08:24:29 PM »
the wings level problem , tweak the flaps
« Reply #13 on: April 15, 2017, 09:52:37 PM »
   Oy, "remove the extra head shims and use a .271 venturi and an APC 12.25-3.75" somehow translates into "leave the head shims alone and use a .265 venturi with a Master Airscrew 13-4".
     I take it now that you find the run acceptable?   An excessively small venturi will only reduce the power, it should run fine otherwise.
Any suggestions?
   The wing is warped, has an asymmetrical airfoil, or the flaps are tweaked. The measurements are not correct in some way. That's a large warp, I would suggest tweaking the flaps until it is the same upright and inverted.
« Reply #14 on: April 16, 2017, 05:36:39 AM »
Hi Chris,
No castor added. The fuel is stock Omega with ~10% nitro.
Hi Mark,
I know that wing warp is there but I cannot see and measure it. The same with flaps.
To counteract the aerodynamic roll moment I have added small "aileron" type tabs set now at + - 3 deg. but they do not work. Perhaps they are too small or they should be deflected + - 15 deg.?
Hi Brett,
On April 11, I have removed the added head shims and tried to run the engine still with MAS 13x4 but it run consistently backwards.
The compression ratio was such that it was difficult to even flip the prop without the kick back from the engine. Also, the engine was flooded and was spewing the raw fuel from the muffler.
After trying unsuccessfully for two hours, I went home and added all the shims as the engine run with them on April 10. I also measured the venturi choke area diameter again after removing the entire venturi assembly from the engine for the ease of access.
This diameter was 0.265 -0.260" depending where I measured. The Al tube I used for the venturi choke area insert is soft and was probably slightly distorted when I was pushing it into venturi.
I took APC 12.25x3.75 with me and went to the circle.
Unfortunately the engine, still with MAS 13x4, was running backwards but was of course much softer.
"What is the root reason that this thing runs backwards without and with shims?" I thought but had no answer.
"Perhaps 0.265-0.260" venturi is too small and the engine is choked to death?"
I was ready to go home knowing less than before but, as the last resort, decided to check the spray bar fuel delivery hole position.
With larger venturi choke area diameter (0.285"), the fuel delivery hole was positioned sideways and I left it this way when I choked the venturi area diameter to 0.265-260".
Comment: "sideways" means that the fuel delivery hole axis was perpendicular to the air flow direction in the choke area.
The fuel delivery hole was indeed still sideways.
"What will happen if I turn the spray bar 90 degrees for the fuel delivery hole pointing directly towards the shaft?" I asked myself.
I did it and the engine (still with MAS 13x4) started with the second flip.
In the meantime I kept incrementally tightening the NVA brass cup nut and the needle stays now in the set position despite the vibrations.
Comment: I also kept tightening the muffler mounting screws and the muffler vibration, though still present, is now much smaller.
Conclusion: I will try APC 12.25x3.75 propeller with this setup and without the head shims and then increase the venturi choke area diameter to 0.271" but first I have to fix the wings and flaps warp problem that I cannot see and cannot measure.
Comment: I do not have reamers and changes in the venturi choke area insert inside diameter can be measured only by caliper. It may be almost impossible to enlarge the insert inside diameter in 0.001"-0.002" increments using the sand paper rolled on a stick.
Best Regards and thank you all for comments and suggestions,
M
