I have this NIB OS LA .40 for The New American.
1) It appears as though I have to drill the needle valve hole to fit a common needle valve bar assembly, as the bar is a bit larger in diameter. Correct?
2) What assembly are they using? I have a few.
3) Tongue mufflers, what are they using?
4) Most common one?
Someone told me Aero Products ruled!
Charles
