  • June 22, 2025, 09:58:11 AM
Author Topic: Stalker 40 RE  (Read 1703 times)
Offline Roger_Pion
Stalker 40 RE
« on: September 24, 2008, 04:19:27 PM »
Anyone with experience with the Stalker 40 rear exhaust, how does its power stack up against the other commonly available .40 engines like the Brodak, OS LA, OS FP, etc.  What general type/size of plane would you recommend for this engine and how would you expect to run it, e.g. wet-2; 2-4-2; prop choices?
Thanks in advance!
Online John Miller
Re: Stalker 40 RE
« Reply #1 on: September 26, 2008, 03:30:04 PM »
Hi Roger
I have 2 Stalker .40RE's set up in different sized, and styled planes. One is serving in a kit built Vector 40. It handles the small plane with good authority. I use FAI fuel, an 11 X 6  2 blade prop, and launch about 86 to 88 k rpm.
The other plane is considerably larger, 620 sq inches, but the weight is in the mid 40 ounce region. I use a 10 X 6 3 blade, and again launch at about the same rpm. Here in Salt Lake City, where the altitude is over 4600 feet ASL, the engine has the power needed, but tends to require a bit higher launch speed on the longish lines I'm using. I expect that shortening the lines a foor or two, will make the wingover less of a free flight event. Everywhere else the line tension is fine. The same setup at lower altitudes has worked very well. The runs are consistent, and reliable.
I would consider using the 40RE in most cases, for a 40 sized plane, unless it was a real porker. In that case, consider the .51RE, a sweetheart of an engine.
Offline Roger_Pion
Re: Stalker 40 RE
« Reply #2 on: September 26, 2008, 05:18:06 PM »
Thanks John.  I have a Vector 40 kit, I guess I'll try this engine on it and see how it works.
Roger Pion
Offline adam collver
Re: Stalker 40 RE
« Reply #3 on: August 26, 2013, 01:55:29 PM »
How much is a 40 re and is there a lot of mods to do to accomodate the pipe.
Online Mike Alimov
Re: Stalker 40 RE
« Reply #4 on: August 28, 2013, 07:53:20 PM »
To the best of my knowledge, the Stalker 40 RE is not made anymore, the closest is 46 SE (side exhaust), here for $238: http://www.technohobby.com.ua/online-shop/en/engines/stalker
You don't want to put a pipe on those, they are made to run 4-2 break out of the box at 8-9 k RPM with 5-6" pitch prop.
