  • June 18, 2025, 01:27:32 AM
Author Topic: Blank  (Read 4081 times)
Online Rusty
Blank
« on: December 18, 2020, 08:42:20 AM »
Blank
« Last Edit: March 10, 2022, 08:01:14 PM by Air Master »
Re: MECOA workmanship defect
« Reply #1 on: December 19, 2020, 02:41:14 PM »
Not all con rods have holes for lubrication.  The rod for the 2-cycle engine operates in an oil-rich environment.  Normal capillary attraction should provide enough lube.
Online Lauri Malila
« Reply #2 on: December 19, 2020, 02:52:58 PM »
Think about it; even at low rpm, say 7500, the cycle is 125/second. There’s no place for capillary action there.
Oil has to go in from middle, it makes a huge difference.
And every % of oil you can reduce with clever lubrication design is good in our use. L
« Reply #3 on: December 22, 2020, 06:27:45 PM »
Why not email RJL/Mecoa and ask RJL himself? IMO, if this engine was actually made by RJL, it'd surprise me if they'd use a cast rod, and would shock me if they'd put holes in the casting. I had some Mecoa .28's...they were made in Taiwan. Look for cast-in evidence of where it was manufactured. I suspect yours was made someplace in Asia.    D>K Steve
« Reply #4 on: December 22, 2020, 09:05:52 PM »
Bore & Stroke   22.0 mm x 19.6 mm --- 0.866" x 0.772"
Max Horsepower   1.43 with tuned pipe & 20% nitro
Practical RPM range   2,000 ~ 17,000
They look like a  SF OS clone .
Offline Chris Wilson
« Reply #5 on: March 13, 2021, 07:26:50 PM »
Ok, I will bite - why does oil have to go in from the middle?
Looking at a single overhung crank it is logical that the crank web is an oil slinger and the big end of the rod that rides up against would be the point of entry and all other holes points of exit.
Adding a hole mid way along the journal simply supplies another point of exit so why let the oil out before it's travelled the full length of the crank pin?
Double overhung cranks work the same, the hole in middle is an exit not an entry.
Chris.
« Last Edit: March 13, 2021, 07:46:55 PM by Chris Wilson »
MAAA AUS 73427
« Reply #6 on: March 13, 2021, 10:07:57 PM »
The holes open the bearing to all the splashing oil. If you've ever seen an engine with a clear plastic back plate you understand. Also, when the rod sweeps across the closely fitting bottom it plows the oil and if there's a hole there oil gets pushed in.
Motorman 8)
The bearing already has two massive holes open for lubrication at either ends.
Putting a hypodermic size pin prick mid length is never going to overide those as major points of entry.
MAAA AUS 73427
« Reply #8 on: March 15, 2021, 05:47:13 PM »
https://www.sciencedirect.com/topics/engineering/connecting-rods
 :P
Um, thanks for the link but I dont see the relevance here.
  Model engines use a single overhung crank with a mist of fuel entering from one side and as such are highly assymmetrical.
Every example in the link seems to use a double overhung crank with a pressurised feed and is highly symmetrical. Taking example of that is fraught with misconception, and again every example (except for the rifle drilling) shows that slots and holes are exit not entry points.
  The only way we are ever going to resolve an argument like this is with wear patterns.
  This is my logic, with an assymmetrical system oil entry is undoubtably the same, one side will simply allow more flow to enter and similarly the other more flow to exit. Witness a standard conrods big end with no added holes or slots to confuse the issue.
It works, it allows oil to enter the eye and oil to exit but in which direction?
  From a fluid dynamic point of view you could argue that it is from the direction that the oil is presented to it, so in a typical front induction model engine that is from front to back and thus the front of the eye receives higher pressure and conversely the rear is a lower pressure area being further away.
  From a mechanical point of view a single overhung crank flexs the further away you apply force from the supporting bearing and thus the load bearing crank pin angles away from that load. This allows the rod that applies the force to migrate away from the support, in other words part of the rods mission in life is to walk off the big end and collide with the backplate. No matter how much running clearance you allow between the rods big end to the static backplate and driven crank bearing it will always tend to be assymerical also and a bigger oil entry point presented at the supported end. (There are of course ways to limit this by capturing the little end PAW style to centralise the rod, under cutting the crank pin and the use of hardend disks to lower friction and control damage) but all of these methods recognise what I have just outlined.)
Also holes and slots introduce points of failure and with a model two stroke the big end is the most critical part of the engine.
  Circling back to fluid flow the greatest gain is to be found in enlarging the exit as you can only get an amount of oil into a bearing that is matched or exceeded by its exit. It makes no sense in claiming the extra provision of entry points gives benefit when there is no matched oil exit.
Attempts to enlarge the entry points have included cutting a cross in the front of eye that effectively enlarges catchment area but even that seems to be in effective and it was last seen in production engines with ETA.
  So if you accept that lets look wear patterns, I have seen Super Tigre speed engines, the same model used and developed year by year using different rods, and every time a drill hole was used in the lower eye it resulted in greater wear on the backplate and it was concluded that the oil hole was allowing the oil out of the bearing before it had time to do its job and lubricate the entire length.
  All the evidence that I have seen points to bearing perforation allowing oil to escape and the flow is away from mechanical support.
  Now the fact that oil holes in this application seem to be of benefit leads me to believe that they are exit not entry points. In a different application where both ends are supported or double hung as in little ends it still appears to be the same, the only difference being that both eyes equally support the entry and this system really does need a dedicated exit point.
Why does all of this matter? If it understood then progress can be made all the better.
If I am wrong then I look forward to a refutation on the above.
Chris.
MAAA AUS 73427
« Reply #9 on: March 17, 2021, 12:43:31 AM »
Steve,
I have a "MECOA 46 Aero Control Line w/ Muffler," stock number 99-M4651.  There are no country of origin markings on the outside of the engine. On the MECOA box, it says "Assembled in U.S.A. from domestic & foreign components. As far as I'm concerned, that is a lot better than a straight "Made in China."
I look forward to trying it out one of these days.
