  • June 27, 2025, 05:22:02 AM
Author Topic: A question about ST 60  (Read 1224 times)
Offline MarcusCordeiro
« on: February 16, 2013, 02:52:35 PM »
Hi guys
Could anybody with more experience on these tell me if there's any difference between these 2 models of ST 60?
I mean, regarding performance...
Thanks a lot
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Re: A question about ST 60
« Reply #1 on: February 16, 2013, 07:34:20 PM »
There was  huge differances between the early and late ones, along with the muffler luggs, The later ones had higher compression heads, PDP porting, Better bushed rods, that were thicker and stronger, Better pistons, Thicker more stable sleeves, and the cranks were changed to a more scalloped shape instead of the T shape, plus the metal was better in the later ones, unless you  got a real chromed ST, most had "chromed" cast into the case, but most were bot
« Reply #2 on: February 16, 2013, 07:43:59 PM »
Thanks Randy
I have 2 of the late ones, and got the other from a friend, and it was a very good price. It seems OK, good compression, bearings running smooth...
The idea is to use it in a nostagia 30 model, very much probably a profile Stilleto from Walter Umland.
Need a venturi and NVA for it.
Anybody has one to spare?
Let me know.
Marcus
Aces High!
« Reply #3 on: February 16, 2013, 08:35:07 PM »
I make them to order for that ST , I also have PA NVAs  that fit. Mufflers ,and I have by the way ST 60s  and 46s  in stock for sale
If I can help on anything let me know
« Reply #4 on: February 17, 2013, 02:04:30 PM »
PM sent
Thanks a lot
Marcus
Aces High!
« Reply #5 on: February 22, 2013, 07:13:48 PM »
Hi Randy
Sent another PM ;D
Marcus
Aces High!
