  • June 15, 2025, 10:59:06 PM
Author Topic: 6949 Is this the correct p&c set for a K&B .19 engine circa 1972?  (Read 1822 times)
Offline frank mccune
            As the heading states, is this the correct p&c for the K& .19 engine?
             Frank
Online bob whitney
Re: 6949 Is this the correct p&c set for a K&B .19 engine circa 1972?
« Reply #1 on: March 03, 2022, 01:48:56 PM »
where is it
rad racer
« Reply #2 on: March 03, 2022, 04:28:35 PM »
     Hi Bob:
     I took a chance and purchased the set from E Bay.
     Do you know anything about the quality of this engine?
      Stay well,
       Frank
« Reply #3 on: March 03, 2022, 04:55:06 PM »
If it is a Series 71 engine it should fit. Not sure there was any difference in the P/L between the BB and plain-bearing engines. I think right in that timeframe the Veco and K&B used the same parts?
They are decent engines if you get one that hasn't been abused or worn out. They aren't going to have the surface finish of a modern OS, etc. but for their era they were fine. And, it's old metallurgy. More oil, always some castor, be sure your tank setup is bulletproof and won't cause meltdowns,,,,  All the usual stuff.
Online bob whitney
« Reply #4 on: March 04, 2022, 01:50:51 PM »
the K&B 19 and Veco 19 were 2 diff motors  the K&B 19 was an over achieving bushing green head  ,there was 2 versions of the piston and sleeve, the original sleeve ports had square edges  .the later ones has rounded ports and had much less compression.. Bill Wisnewski turned 154 mph at the nats in A speed with one just before they went to 15's the same year the winning B speed was 153mph by Arnie Nelson with a combo of a McCoy case and K&B 29R Silver head guts with a BB front end
Fox put a lot of effort into trying to beat the K&B  and never did.it is hard to believe it went that fast but i saw the flight.today u could put the whole motor in side of a rossi 15.  Blast from the past RAD
 the newest K&B 19's were a Scherle BB 3.5 with a shorter stroke making them 3.25 for Free Flight
rad racer
« Reply #5 on: March 04, 2022, 06:26:01 PM »
     Hi Bob:
     The engine in question is a K&B .19 Series 71.
       Frank
Online bob whitney
« Reply #6 on: March 04, 2022, 08:43:39 PM »
i would like to see a picture of it or the parts
rad racer
« Reply #7 on: March 08, 2022, 04:10:01 PM »
Yup! Pictures! There's likely some confusion since K&B took over the Veco .19bb followed up by RJL taking over the K&B (and K&B/Cox Conquest .15), dropping the plain bearing Green Head engines. If the fins are integral with the cylinder, it's for a Green Head. I never owned any K&B Green Head engines and I'm happy with that. And have no idea when K&B took over the Veco .19bb and dropped the GH stuff. I had some K&B Series '61 .35's that were a POS, so....
I did have an early Veco .29 that was made by K&B under contract, but it "blowed up" due to the cast aluminum conrod. Later, I found out that K&B had changed their own .29/.31/.35 to a steel rod, but kept putting out the Veco .29 with the aluminum rod that broke easily and regularly. These were prior to the GH series.  '' Steve
PS: It may or may not help to look for PN for the RJL/K&B/Veco .19bb on RJL's website. There's a chance that they carried over the part numbering system from K&B.
« Reply #8 on: March 08, 2022, 04:33:15 PM »
https://www.manualslib.com/manual/1029562/KAndb-Veco-19-R-C-6501.html?page=5#manual
Torpedo , Liners got intregal fins .
K&B boxed ( manufactured ? ) Veco 19 . Must be as late Veco 61s are K&B  logo .
« Reply #9 on: March 08, 2022, 04:36:41 PM »
Radios got cut down intake , and maybe butterfly holes in stack . C/L intakes taller . Box says K&B . injun says VECO .
 6711 is control line .
 6712 is wireless R / C version .
