  • June 20, 2025, 06:56:26 AM
Author Topic: Cox??? little bugger  (Read 1939 times)
Offline Bill Sawyer
« on: August 27, 2006, 06:26:32 PM »
This is one that is smaller than the .049 . Looks like a midgett but I cannot tell if it is a 020 or 010. can someone tell me how to identify it? The prop is held on with a slotted screw and the prop is a white plastic that is 4 1/2 inches long - no idea of pitch. what is this one ??? Anybody?
Bill Sawyer
AMA 53987
Windancer Models
Re: Cox??? little bugger
« Reply #1 on: August 27, 2006, 07:42:56 PM »
IIRC, the 020 had a 4 1/2" prop.  I know the 010 had a prop that was a 3".
Bill <><
Offline W.D. Roland
« Reply #2 on: August 27, 2006, 08:10:08 PM »
prop i think is 4.5x2 if cox and white should be .020
front intake is t.d. intake through tank i think is pee wee.pee wee was black prop?
also was a black 4.5x2 i think and looke like a black master airscrew where the white looked more like t.f. nylon
now days i have to use magnifying glass to even find the numbers on small props.
David
David Roland
51336
Offline Ralph Wenzel (d)
« Reply #3 on: August 27, 2006, 09:19:49 PM »
You didn't specify whether it has an integral tank. If so, it's the PeeWee .020; if not, it's a TD .020. LEt me know if you need glow heads. Same head works for both . . .
Ralph Wenzel
AMA 495785 League City, TX
Offline Bill Sawyer
« Reply #4 on: August 27, 2006, 09:26:27 PM »
Red tank made on back of the engine. Mounted to a piece or angle iron so cant see the rear of the tank
Bill Sawyer
AMA 53987
Windancer Models
« Reply #5 on: August 27, 2006, 11:13:17 PM »
Yep - - PeeWee .020
Ralph Wenzel
Offline W.D. Roland
« Reply #6 on: August 28, 2006, 06:45:18 AM »
red plastic tank/front intake=t.d.
red metal tank/intake through tank=pee wee
easiest might be wich end of engine is needle valve on?
front=t.d.
rear=pee wee
David
David Roland
51336
Offline W.D. Roland
« Reply #7 on: August 28, 2006, 06:48:49 AM »
this might help more
if it looks like .049 baby bee only smaller and red tank its a pee wee
if not is t.d.
David Roland
51336
Offline Bill Sawyer
« Reply #8 on: August 28, 2006, 12:41:38 PM »
From what information that has been given it has to be a PeeWee. Thanks everyone.
Bill Sawyer
AMA 53987
Windancer Models
Offline dennis lipsett
« Reply #9 on: August 28, 2006, 08:08:52 PM »
I have a few of the pee wees and would like to have a few spare plugs for them. If you have 2 to sell I'd gladly buy them from you.  I have a  few spare High compression 049 heads and a few Glow Bee's also, if you need something to swap.
Dennis
Offline Steve Scott
« Reply #10 on: September 02, 2006, 12:28:20 PM »
By far the easiest way to differentiate between the PeeWee and TeeDee 020 is the needle valve assembly.  The PeeWee is a reed valve engine and has the needle valve on the backplate of the tank.  The TeeDee is front shaft induction and has the needle on the intake - in front of the cylinder.
The 2nd most obvious clue is the price you have to pay for one...
