  • June 20, 2025, 10:28:17 AM
Author Topic: os max sr .40  (Read 1406 times)
Offline mark eisenhut
    • madphotos.net
os max sr .40
« on: November 28, 2006, 10:26:22 AM »
i just found one of these sr .40 os max are they any good and what are the worth Ive never seen one before i need your info before i make a mistake the motor look new no mounting marks good compresion and i think it's ball bearing. any help would be welcome and can a fp or la venturi be used?
thank you
mark eisenhut
mark eisenhut
Offline Manuel Cortes
Re: os max sr .40
« Reply #1 on: November 28, 2006, 10:31:15 AM »
Hello, Mark:
If itīs the FSR, I run one during a season, lots of power, I tame retiming the sleeve and fiting a .275 venturi, but it did very well with a Claus Maikis Indigo (beautiful plane, by the way),
Hope it helps.
Regards.
Manuel.
    • madphotos.net
Re: os max sr .40
« Reply #2 on: December 04, 2006, 03:11:20 PM »
Manuel,
  where did you get a venturi .275 for it. i also need a muffler any help is welcomed
thanks
mark
mark eisenhut
Offline Ward Van Duzer
Re: os max sr .40
« Reply #3 on: December 06, 2006, 02:00:08 PM »
Mark,
While there are probably better engines out there for stunt, everything you need can be had from our moderator, Randy Smith.
    • madphotos.net
Re: os max sr .40
« Reply #4 on: December 06, 2006, 04:27:30 PM »
thanks for the info . found everthing at tower hobbies.
thanks again
mark eisenhut
mark eisenhut
Re: os max sr .40
« Reply #5 on: December 07, 2006, 03:53:43 AM »
Sorry, I was out.
My venturi was suplied by Tom Dixon, is the same as OS 46SF and OS 40 SF.
Regards.
Manuel
