How about *4 bladers*, Randy?
HI Bill
Randy's post is correct, many 4 blade props are high aspect ratio and thin. People making 4 blades by just screwing or milling slots and putting 2 wood props together are most likley going to need to go at least 1 inch down size, and maybe even up to 1.5 to 2 inches. This will depend on how easy the prop turns.
Interesting , I have found 4 blades to drive very good and give a "turbine" like feel to the motor-plane..however they are very noisy. Some will really howl.
Stick with an odd number of blades if you want quiet! even numbers are much more noise
