  • June 21, 2025, 11:57:46 AM
Author Topic: 4-2 break  (Read 1381 times)
Offline mike mullis
4-2 break
« on: November 22, 2007, 05:39:55 PM »
was wondering if someone wouldn't mind explaining this to me..i read about an engine doin a 4-2 or a 4-2-4 break and was curious as to what that exactly was...thanks for any info
Mike Mullis        LaVergne,Tennessee
Offline Jim Thomerson
Re: 4-2 break
« Reply #1 on: November 22, 2007, 06:33:41 PM »
Some engines, notably the old Fox Stunt 35, will run in an real 4-cycle when run a bit rich.  The engine will fire every other stroke.  The power is about 70% because the fuel/air charge is better from when the engine did not fire.  When the engine is loaded as in maneuvers, or leaned out, it will go into a normal 2-stroke mode.  Take off the load and it goes back to 4-stroke.   It is impressive to watch an airplane fly the stunt pattern when this works exactly right.  I just run in a rich 2-stroke and let it go at that.  More knowledgable people will clarify and correct my comments.
Offline mike mullis
Re: 4-2 break
« Reply #2 on: November 24, 2007, 05:09:53 PM »
thanks for the reply Jim
Offline L0U CRANE
Re: 4-2 break
« Reply #3 on: November 24, 2007, 05:52:03 PM »
Mike,
I'd only add to Jim's excellent description that you remember he said: "Some engines, ..."
Most mass produced modern engines could probably be worked around a bit, even if only with head gaskets, prop, fuel, plug, possibly some metal cutting inside... to yield this auto-switch from purr to shriek type of run. They aren't designed to do that out of the box, IOW.
For these engines, as Jim says, it is so much simpler to run in a low-2-cycle. That's more like what modern engines were designed to do, so they do it well, and last a nice long time that way. ...And they give more of the power they were designed to produce this way.
The Fox 35 is essentially unchanged since it first came out around 1950, and it still does well what it was designed to do. Odd fact: when the sound changes from purr to shriek, there is very little, if any RPM gain with the Fox 35 Stunt. ...just enough. Even the Fox 35 gains from certain practices that help it do its traditional thing, but those are well known. If you need to learn about them, ask! After you weather a storm of people asking you why you want a dinosaur to tow your plane around, you'll hear that a proper break-in is a great help, and (most often) that fuel with well over 25% all castor oil is a sure success with it.
As Jim said, when you hear a stunter going through a pattern in a 4/2-break setting, it is still impressive!
\BEST\LOU
Offline Ron King
Re: 4-2 break
« Reply #4 on: November 25, 2007, 07:19:38 AM »
Quite a few of the modern, purpose built stunt engines also do a good 4-2 break. The Double Star engines sound like John Deere tractors in level flight, then do a nice break when you pull the nose up. My RO-Jett 61 with a header muffler works and sounds the same.
My PA piped engines run a perfect 4-2 break. It sounds a little different coming from the pipe, but the sound change and the RPM change are very noticeable.
Randy has also designed the Aero Tiger to do a 4-2 break. It's a little harder for me to hear, but the "burble" in level flight gives it a smooth consistent feel, that breaks into a nice 2 stroke when the plane hits the 10 o'clock position in a loop.
The whole idea behind this 4-2 break is to give ourselves a little more power when we need it to help us keep a constant airspeed with our stunt ships during maneuvers.
Hope this helps,
Ron
Ron King
AMA AVP District 4
Wannabe Stunt Pilot since 1963
 Amateurs practice until they get it right; Pros practice until they cannot get it wrong.
Offline L0U CRANE
Re: 4-2 break
« Reply #5 on: November 26, 2007, 01:06:18 AM »
Ron,
Thanks, and excellent points, all.
I referred to the mass-produced, general (i.e., mostly RC) market engines availabe at bargain prices these days. They DO work, as I described it.  The purpose-designed/built CLPA engines cost a bit more and are a bit harder to locate for those just coming back into stunt.
With all the resources - like this forum - a new or retread flier can come up to whatever level of "speed" he/she likes.
It is a hobby, something we do because we wish to. That leaves the choices up to us, wherever our motivations and circumstances might lead
\BEST\LOU
Offline Ron King
Re: 4-2 break
« Reply #6 on: November 26, 2007, 06:26:44 AM »
Lou,
I definitely agree with you and hope there was nothing in my post that implied otherwise.
We live in an RC world today. As an AVP for the AMA, I have 300 RC guys for every CL guy in my local area - and that's only because we have an active CL club here in Northern Virginia.  n~
I was also one of those guys who came back to CL a few years ago and unfortunately I wasted a lot of time, money, and effort trying to recreate the stunt run I remembered from my younger days. The vast majority of RC engines need lots of work to run the way we want and my hope is someone coming back to our side of the hobby will spend their money wisely. Decent, reworked RC engines are available from many of our engine gurus and I agree that the internet should help the retread find the help they need.
Take care,
Ron
Ron King
AMA AVP District 4
Offline mike mullis
Re: 4-2 break
« Reply #7 on: November 26, 2007, 06:59:12 PM »
thanks for all the info fellas...dyin to find the time to get the ringmaster i got and the mustang back up to snuff and get to fly them again soon..i'm bidding on a couple of engines on ebay...couple of fox 35's and what seems to be a real nice os40 that is reworked..venturi, timing etc...all i have now is the merco 35 and merco 40...neither have nva's....and best i rmember the 35 has a bent crank..
(asphault is really hard on a ringmaster)..lol...the last time i ran the 40 was with the 35 nva...it never seamed to come up to power corectly...neither of these engines have alot of run time on em....maybe a dozen times each...i bought these in the late 80's..new in the box from hobby lobby....are these good stunt engines and worth having reworked and such??....wouldnt mind fixin em back up if it wouldnt cost a fortune...my cl budget is slim as my time to fly as we drag race harley davidsons on a full time basis.....i guess looking at the planes hanging on the wall everytime i go to the shop is givin me the itch....we use to fly the wings off cox planes and ringmasters when i was a kid....cant wait to do it again.....and thanx again for the replies.......Mike Mullis
