  • June 17, 2025, 05:56:24 AM
Author Topic: 4-2-4 engine run sans nitro, possible?  (Read 2257 times)
Offline frank mccune
« on: May 11, 2021, 10:55:02 AM »
       Hello All:
        Is it possible to have an engine produce a 4-2-4 run sans nitro.
         I have my thoughts, what are yours?
         Tia,
          Frank
Re: 4-2-4 engine run sans nitro, possible?
« Reply #1 on: May 11, 2021, 11:07:18 AM »
       Hello All:
  Of course, why wouldn't it?  The best/most successful large 4-2 break engine is the Discovery-Retro, it has problems in some conditions even on 5%, and runs fine on FAI fuel.
   There is nothing terribly magical about 4-2 breaks, I am not sure why it seems so mysterious to people.
« Reply #2 on: May 11, 2021, 02:18:05 PM »
     Hello Brett:
     That is what I thought.
      Thanks for the prompt answer.
      Stay well,
      Frank
« Reply #3 on: May 11, 2021, 05:11:34 PM »
       Hello All:
         Tia,
          Frank
Frank  you can get a  no nitro 4/2 run on many many  engines,  Fox 35   ST 46  ST60   Aero Tiger  any  PA   and  a host  of  other  engines
Offline Chris Wilson
« Reply #4 on: May 12, 2021, 05:08:31 AM »
Petrol and spark ignition also 4/2 quite nicely, just ask some vintage flyers.
Chris.
MAAA AUS 73427
« Reply #5 on: May 12, 2021, 08:47:05 AM »
Chris.
   A Lawn-Boy lawn mower (the older 2-stroke version) would very happily break from a rich 2 to a lean 2 when it hit higher grass. You had to really screw up the setting to get it to misfire at no load, although you could do it, then you got a 4-2 break.  That with constant spark timing, constant fuel supply pressure, constant everything else - except for varying the load.
   QED.
Offline Brad LaPointe
« Reply #6 on: May 12, 2021, 08:59:56 AM »
Lawn Boys shake too much for a profile .
Brad
« Reply #7 on: May 12, 2021, 09:11:05 AM »
You can never have too much power!
« Reply #8 on: May 12, 2021, 03:18:53 PM »
Would love to know if an OS Wankel engine might hold a 4/2 setting.
The free flight spark boys experienced the 4/2 probably before anyone else but had no idea what to do with it.
Go figure.
Chris.
MAAA AUS 73427
« Reply #9 on: May 12, 2021, 09:59:36 PM »
Geeze Brett , now everone'll want one . theyre only $ 400 new . F2B will never be the same now .
https://www.ebay.com/itm/254266398483?hash=item3b33755713:g:5REAAOSw-HxdBvDa
« Reply #10 on: May 13, 2021, 02:40:31 PM »
      Hi Brett:
       I will bet that the sound that you hear on the Lawnboy changing rpm is due to the action of the governor!  I have never heard a Lawnboy run in a four cycle. Perhaps I did not recognize the four cycle sound.
        As I type this, I am rebuilding a 5269 and the next project is short blocking a 5029 Brickhead.  I just can not say no to a D engine.  To me they are the greatest mower ever sold.  My wife trims with a 19” 5239 and loves it!
         In any case, stay well,
          Frank McCune
« Reply #11 on: May 13, 2021, 04:51:49 PM »
      Hi Brett:
    Does the same even with the governor defeated. And I have intentionally set it super-rich to convince myself that it was just the load (45 years ago, when I still had grass to mow....).
p.s. it's just a giant version of an Ohlsson 23 sideport - which can be induced to do the same thing on ignition.
« Reply #12 on: May 16, 2021, 11:07:30 AM »
   QED.
LOL  my  2 stroke  leaf blower  will run a  4/2,  when i adjust the carb mixture  for the different petrols.. it will go into a  4 stroke, and i can set it where it  runs  4/2 back n forth right on the  verge.  It will  kick from 4/2 when you load it with full throttle
