  • June 16, 2025, 02:13:27 PM
Author Topic: 3 blade props for LA 25, FP 25, Magnum GP25  (Read 1600 times)
Online Allen Eshleman
« on: July 06, 2020, 04:06:45 PM »
I know that a two blade 9/4 is the standard place to start with LA 25's, FP25's and Magnum GP 25"s.  I am finding a problem with Landing Gear not being long enough and so the ends get clipped off when taking off.  It happens more when using my stooge.
Has anyone tried 3 blad props with these engines and if so, what worked?
Re: 3 blade props for LA 25, FP 25, Magnum GP25
« Reply #1 on: July 06, 2020, 04:29:51 PM »
If you can find a 3 blade 8/4 prop it should work pretty well.
Saw APC has a 9/4 4 blade, probably a bit much.
« Reply #2 on: July 06, 2020, 07:29:37 PM »
   One potentially good choice, if you can find one, is a Tornado 10-4 3-blade. I have seen those used on even 20FPs, and it more-or-less worked. It works very well on a 25FP and probably pretty good on a 25LA.
« Reply #3 on: July 06, 2020, 08:45:28 PM »
Were 8 x 6 Tornado 3 blade . If theyre like the 10 x 6 , theyll be about a 5 . Theres even 7 x 6s & maybe ? a 8 x 4 . The FSR 25 was a bit limp on a 10 x 4 3 Bl . Equivilent of a 11 x 4 maybe .
Look up ' Grish - Tornado . ' 436 hobbies in NZ had them . :P Found theres a flight differance between the black & stiff silver , too . The BLACK suits the G - 51 . Silver the 21/46 . ???
« Reply #4 on: July 07, 2020, 05:26:28 AM »
I found a Master Airscrew 8x6.  Has anyone ever tried it with a 25?
« Reply #5 on: July 07, 2020, 02:50:12 PM »
Dick Mathis' original Chizler in colored tissue/clear dope finish used a Tornado 10-4 prop cut down some.  That was with a Fox .35.  He placed 2nd with it at the 67 Nats behind Bart Klapinski.
I have no idea if he changed the pitch, which you could do with those Tornado gray props.
« Reply #6 on: July 07, 2020, 04:57:13 PM »
Keith,
I assume that Dick would have needed to run the Fox in pretty much a flat out 2 cycle mode maybe one of the first to run low pitch - high rpm.
Best,   DennisT
« Reply #7 on: July 08, 2020, 05:18:15 AM »
I see that Master Air Screw has a 7/4 also. I haven't decided to buy either one yet but the 8/6 and 7/4 would be interesting experiments.
« Reply #8 on: July 08, 2020, 08:28:54 AM »
Allen,
I have used the Master Airscrew 3 blades and one thing I found was they are 1" pitch low for the marked pitch. I wound up using a 9x7 and found it saw about the same as a 6" pitch.
Best,   DennisT
Offline Dave Moritz
« Reply #9 on: July 08, 2020, 09:30:08 AM »
Allen:
Larger wheels an option?
Dave Mo...
« Reply #10 on: July 09, 2020, 02:38:59 PM »
"Larger Wheels"
Great idea!
« Reply #11 on: July 09, 2020, 02:43:19 PM »
Btw, I ordered 2 8/6 MAS 3 bladers, 1 7/4 and 1 10/5.  My idea is to try the 8/6 on my 25's.  I am not sure about trying the 7/4 on a 25.  The 10/5, I may try on my LA 40, and some plane with my Brodak 40.  The B-40 is on a twisted wing Magician and I don't think I will try it again.  I don't know if the 10/5 would be too small for an LA 46.  I just ordered them today.  Looks like an almost two week wait.
