  • June 16, 2025, 03:07:32 PM
Author Topic: 2002 NIB Brodak 40 spray bar  (Read 1135 times)
Offline Leester
« on: January 07, 2020, 12:05:31 PM »
I just purchased a NIB 2002 Brodak 40. I was changing the needle from one side to another and noticed the spray bar has two holes drilled in it one across from the other ??? Is this defective spray bar or is it suppose to be like this ??
« Last Edit: January 07, 2020, 01:26:58 PM by Leester »
Leester
ama 830538
Offline Leester
Re: 2002 NIB Brodak 40 spray bar
« Reply #1 on: January 07, 2020, 01:30:00 PM »
Not sure I follow what your saying. I've never seen a spray bar with the holes going threw front to back ??
Leester
ama 830538
Offline Leester
« Reply #2 on: January 07, 2020, 03:14:43 PM »
I've been educated on the two holer's (lol)
Leester
ama 830538
Offline Peter in Fairfax, VA
« Reply #3 on: January 09, 2020, 08:53:46 AM »
Two hole spray bars (straight through drilling) are not that unusual, as this is what is supplied with a Fox .35.
The basic concept is the venturi effect creates a vacuum that draws fuel through the spray bar.  There are a lot of opinions and observations about where the hole or holes should point, resulting in an opinion that the vacuum will draw out the fuel in many orientations.
Peter
From Stuka stunt:
> RE: Fox 35 spray bar position"
It's supposed to be front and back, or, with the axis of the holes at right angles to the axis of the venturi. However, it really doesn't matter very much at all. I have seen them run perfectly well with one hole up and the other down.
