  • July 07, 2025, 02:33:51 AM
Author Topic: 2 STROKE TO 4 STROKE CONVERSION  (Read 1259 times)
Offline Kelly Wilson
« on: August 11, 2008, 11:48:49 AM »
Whats a good rule of thumb for conversion on various kits/planes to 4 stroke engines?  Should it be by wing area ?? plane weight ?? percentage of 2 stroke displacement??  Most of the R/C kits have a recommendation, but I haven't seen anything on control line kits.
Kelly
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: 2 STROKE TO 4 STROKE CONVERSION
« Reply #1 on: August 11, 2008, 02:26:32 PM »
Most of us have found direct displacement substutes work well.. In some cases we have actually gone to a smaller 4 stroke, for example a Saito 56 will fly anything designed for a ST 60 and some, including me will say the Saito would be a better choice.
« Reply #2 on: August 11, 2008, 04:36:19 PM »
Kelly
HI Kelly
There is not any real rule of thumb that works "across the board", you  would be best taking it on a case by case basis, and it will depend on what CL aircrafts you are asking about, stunt planes ,carrier, scale, sport, etc  . The engines could be ran very differently in these
Are you asking about strictly Stunt aircraft?
« Reply #3 on: August 11, 2008, 05:54:37 PM »
Hey Randy,
Basically stunt and sport. I already had a pretty good feel for it, I just wanted to get some other opinions. What Bob says makes good sense too. As a general rule the 4 stroke is going to pull a larger prop at a little less rpm although  some what steadier rpm.
I would appreciate hearing any one else's opinion and thoughts on the subject too. I just picked up a deal on one of the new OS 56a 4 strokes. Anyone had any experience with one of those?
Kelly
Offline Scott Hartford
« Reply #4 on: August 12, 2008, 04:32:39 PM »
I use one for RC and it compares very favorably to the Saito 56. Actually it leaks less oil.......
