  • April 26, 2024, 10:23:48 AM
Author Topic: Blank  (Read 1597 times)
Offline Rusty
Blank
« on: May 25, 2021, 06:11:52 PM »
Blank
« Last Edit: March 10, 2022, 07:22:48 PM by Air Master »
Offline Air Ministry .
Re: #2: Cleaning an engine for storage after using it.
« Reply #1 on: May 25, 2021, 10:55:14 PM »
Flush it with alcohol , to disperse nitro residue .Maybe a few times generously .
Plug out to belt over to clear the alcohol . Leave it in the sun .
Oil it well . MINERAL OIL is said to beat syntehetic any day. For STORAGE .
But someones just got a litre of chainsaw bar oil . Which is sticky & recomeded for machined motorcycle componetry etc .
Whaddeva ya do , KEEP IT AWAY FROM THE DAMP  .
Offline Peter in Fairfax, VA
« Reply #2 on: May 28, 2021, 10:37:19 AM »
Myself, here's what I'd advise:
1.  With a prop, plug and backplate installed, put half a dozen drops of Air Tool oil or ATF into the intake.
2.  Flip it over a dozen times.
3.  Remove the prop.
4.  Possibly brush a little of the oil/atf onto fasteners (screws, prop nut/shaft)
5.  Wrap the engine in a paper towel.  Absorbs some moisture and blocks some UV.
6.  Zip loc bag, possibly evacuated of air, as convenient.
If it's mounted on a plane, oil it, then wrap it with a rag.
Offline Daniel_Munro
« Reply #3 on: May 30, 2021, 03:27:17 PM »
A few drops ATF down the venturi and flip it through several times does the trick.
NZL7396
Offline Chris Wilson
« Reply #4 on: May 31, 2021, 02:39:50 AM »
I agree with most of the above but wish to add, leave  the exhaust port open if possible so that any unburnt hydrocarbons can gas off.
MAAA AUS 73427
« Reply #5 on: June 09, 2021, 06:47:53 PM »
Purloined from :   https://combatflyers.co.uk/howto-rothwell1.htm                             via Baton Forum .
"  It occurred to me that some of the R320 users may not be used to storing ball raced engines.
As your competition season has now ended there may be a few R320's which won't be run for a month or more and if they aren't lubricated properly now, then they will need new bearings next season, and if a bearing fails in use it can do much worse damage to the rest of the engine.
Castor oil is a fantastic lubricant but after running it dries out and eventually gets to the point where the balls in the bearings don't roll but skid.  It is very difficult to wash out once it has gotten to this stage.
For long storage ( more than a few weeks ) I recommend that the engine is removed from the model, spray inside and out with WD40 or similar, then lubricate with after run oil.
There are many good oils for this purpose, I use and recommend automotive automatic transmission fluid.  Some down the venturi, in the exhaust and around the prop driver, put in a few drops and flip it over, a few more and flip it over, don't over do it and you do and it locks as you try to turn it over simply allow the excess to drain out the exhaust.
Wrap the engine in a rag and as long as you are sure there is no moisture present you can also pop it in a plastic bag and store it in a dry place.
After every days flying they should get a spray with wd and then lubricated with the after run, it would most likely be fine for a week but often a week turns into 2 then 3 and so on, and before you know it there is a problem which could so easily have been avoided.
If the engine is expected to be stored for only a few weeks then by all means leave it in the model but give it the oil.
Before starting for the first time flush it through with some fuel to wash the oil out.
With this treatment I have engines which have been used for years with out a bearing change, and on the other hand seen too many with only a couiple of hours running ruined through neglect.
Steve Rothwell "
Apparently MINERAL OIL , rather than Syntetic , is the go . Tho Syntetic ATF along with 1/3 power steering fluid , is better in power steering . Unless its electric .  ??? S?P
« Reply #6 on: June 10, 2021, 01:51:22 PM »
I think that, in the very least, the back plate should come off so you can spray the inside with carburator cleaner, in addition to spraying inside  the cylinder (above the piston).  Then you could spray some fogging oil or air tool oil in both places.
What do you guys do to keep your engines from locking up in storage?
   You should never take an engine apart unless there is something wrong with it.
    I have had satisfactory results using air tool oil, dribbled in right after the last run, and then occasionally (every few years) taking them out and turning them over. I have yet to find anything that will not eventually gum up, however, heat usually fixes that. Of course, you could take everything apart, clean it, then reassemble it (with light machine oil like Singer Sewing Machine Oil), but again, you should never take an engine apart unless there is something wrong with it.
« Reply #7 on: June 10, 2021, 08:38:03 PM »
As recommended by George Aldrich, I use Rislone Oil Treatment.
I've started engines after thirty years with no problem.
Don't believe me?  Rislone an engine and try it in 2051.
« Reply #8 on: June 10, 2021, 10:10:21 PM »
   I have to remember to check at the auto parts store to see if it's still made. I have come up with a couple of cans of the stuff and knew that was what George recommended for prelube at assembly and for storage. I think the F2A guys that come here use a mix of kerosene and 3N1 oil. Sewing machine oil would be a good substitute. They flush their engines at the end of each flying session. Sewing machine oil doesn't get gummy. I got to look at some old machines that had been sitting for years at my last job before we got rid of them and they cranked over by hand as easy as pie. It doesn't have much viscosity but gets pretty slick. I spent the last four years before retirement working on and repairing CNC multihead sewing machines. Your would be amazed at how few bearings there are in 18 head machine with 15 needles on each head. All critical lube points are either bushings and steel or steel on steel. I was really enjoying the work until Mr. Covid reared it's ugly head and gave the owner an excuse to shut the place down. You can probably buy sewing machine oil at any place that services home sewing machines but to get it in a larger quantity you need to see a supply house for custom embroidery shops.
« Reply #9 on: June 15, 2021, 02:34:01 AM »
Any oil with a high detergent content will do, it doesn't need to be branded ATF, sewing machine oil or Risoline.
The key is the surfactant.
Chris.
MAAA AUS 73427
« Reply #11 on: June 15, 2021, 04:39:26 PM »
Interestingly they state it's non  detergent but not non surfactant and I  wonder what their secret sauce is.
Of course we may never know.
Chris.
MAAA AUS 73427
