Engine basics => Engine set up tips => Topic started by: charlie on January 10, 2011, 04:07:10 AM
I have a question for anyone that can give me an explanation. The 100 series Veco .35 is a good 424 running stunt engine, but the 100 series .19, which has, as far as I can determine, the same port timings is anything but. No matter how rich I set it, once in the air the thing goes beserk and just howls around. Can they be tamed? I have tried lowering the compression with head shims, but the only difference that I could see was that it became (a lot) harder to start. This isn't just in one model/tank setup. It has been in several planes with different tanks and it always behaves the same.
I would like to know why.
Charlie
