  • June 23, 2025, 09:49:46 AM
Author Topic: 0 vs 9% Nitro fuel results  (Read 2155 times)
Offline Terry Caron
« on: March 08, 2015, 05:31:12 PM »
Hi all -
Some may have searched, as I have, for data on no nitro compared to some nitro in various engines.
I didn't set out to do a rigorous test sequence, so I'm simply offering results as noted on the bench from some of my engines.
These pretty well run the gamut of c/r and technologies for plain-bearing sport engines.
Strictly empirical of course, but I selected common points. YMMV.
These engines were run during the past year or so, different days, temps, humidity, only 690' ASL and my old Carl Goldberg test stand clamped to the porch rail were the same.  ;D
Fuel even varied +/- 1%ish, in 16 oz batches, as I remix Morgan's 15% for ~9% nitro, adding straight castor to 25%; I mix locally obtained methanol and straight castor for 0%.
I've had no problem with starting either mix.
I make no recommendation for any particular mix; you may well have particular requirements.
Factors other than rpm certainly enter into that selection.
I hope you find it at least interesting, maybe even useful.
regards,
Terry
                                          Nitro/Meth/Oil
                           0/75/25                        9/64/25
                           Veco .19
8-4 MAS                 14.5                             15.0K
8-5 APC                  13.3K                           13.8K
9-4 APC                  11.4K                           12.0K
                         OS .20FP steel
9-4 Zngr                 12.6K                        (n/r) (not run)
9-6 MAS                  9.9K                              (n/r)
        note: I do fly these OS .20s on 9% fuel.
                         OS .20FP ABN
8-4 APC                   13.1K                            (n/r)
                            O&R .23
                     #1             #2                 #1          #2
9-4 APC          11.8K        11.6K               12.1K     11.9K
9-6 APC          10.2K        10.4K               10.7K      (n/r)
                         OS .25FP ABN
9-4 APC                  13.7K                            15.0K
10-4 Zngr                11.0K                            11.7K
                        McCoy .29 1952
9-4 Zngr                    8.5K                           8.5K
                           Enya .35-III B
10-4 Zngr               11.5K                            11.7K
10-6 MAS               10.6K                            10.8K
                              OS .46LA
11.5-4 APC            10.4K                             10.8K
12.25-3.75 APC      10.1K                             10.4K
« Last Edit: March 08, 2015, 06:42:49 PM by Terry Caron »
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Offline frank mccune
Re: 0 vs 9% Nitro fuel results
« Reply #1 on: March 09, 2015, 07:10:45 AM »
    Hi Terry:
    Your results are  about the same as mine when I tested FAI fuel vs. 5% fuel!  I did notice that the 5% nitro made the engines easier to start and much easier to set the needle valve.
    The worst engines on the FAI fuel was the Fox engine and the ST, OS and Enya engines seemed to like the FAI fuel.
    Thanks for the information,
        Stay well my friend,
        Frank Mccune
« Reply #2 on: March 09, 2015, 10:44:56 AM »
My feeling from lots-o-reading -- backed up by only a minuscule amount of real testing on Cox 049 engines with hand-modified heads -- is that just changing the fuel in a given engine without changing the compression isn't telling anything at all like the whole story.  Changing the amount of nitro in the fuel really changes the optimum compression ratio -- at low nitro level, engines like more compression, and visa-versa.
If you were really going to do a fair test, you'd start with engines that have compression a bit high for no nitro, you'd experiment with head shims for each fuel until you found an optimum combination, and you'd publish the best results for each fuel/compression combination.
Even then, just getting the numbers from bench runs won't tell you how fit the combination would be for a good stunt run, or suitability for team race, or whatever.
Offline Terry Caron
« Reply #3 on: March 09, 2015, 11:11:37 AM »
I agree completely Tim.
I suppose the only conclusion one can draw from the results I noted are that 'most any sport engine will run on no nitro, possibly to a useful degree.
Nothing more was intended, as that might be the simple answer to someone's question.
regards,
Terry
AMA 249824
NRA Life Member
« Reply #4 on: March 09, 2015, 11:34:04 AM »
  Depends on what you mean about "fair test". Terry's experiment is very much representative of how nitro changes are typically used in stunt. In almost all cases, stunt engines are *far* below the limit of problems so adding nitro typically moves them closer to the optimal compression.
  I treat nitro like an oxidizer - if you are short of oxygen, add nitro. Almost no one who knows what they are doing is changing the compression every time they change the nitro, they have a baseline system and adjust the nitro to get the same performance based on the air density.
« Reply #5 on: March 09, 2015, 11:57:45 AM »
You're right; it depends on what I mean about "fair test".
If the question you're trying to answer is "is nitromethane good stuff to use", or "how much nitro is good" then the answer is complicated, and -- in North America, where engines are generally sold assuming that folks will use lots-o-nitro -- just adding nitro will generally result in "better" performance, in a lot of different ways.  Witness the tests that Terry did, where the OS engines wouldn't even run on no-nitro fuel: upping the compression, or perhaps even changing glow plugs, would change this, but Terry placed that outside the parameters of his test.  So he's not finding out if nitro is good -- he's finding out if nitro is good for that particular engine, as it is set up at the moment.
If you're using nitro as a tuning aid that doesn't require you to mess around with head bolts, then one uses it the way you advocate.  I could see someone who's really an expert adding shims or shaving the head a bit, once, and then carrying on for the rest of a particular engine's career by varying nitro content (there's an active thread involving a Stalker where the advice is to try adding head shims on an engine that's currently running no nitro already, for instance).
I understand that in general, using some nitromethane seems to be a salubrious combination in most stunt engines, in that it helps to make the engine provide a better stunt run over a wider range of conditions.  I also understand that in general, using nitro as a way to compensate for high altitude, humidity, or other conditions that knock power levels, is going to be far easier than trying to find a new prop/compression ratio/venturi combination every time you change 1000 feet of altitude or the equivalent in humidity and temperature.
It would be nice to know what Terry was trying to find out.
Offline Terry Caron
« Reply #6 on: March 09, 2015, 12:10:17 PM »
Brett and Tim, you flatter me unduly - "experiment" is too fine a word.
As I said initially, I wasn't running a test about anything but my engines, and my only interests were - Do they run? How well? How about on no nitro?
That's all I was trying to find out and those are just the notes I took.
My post was made only because I've run across similar questions, with no posted results in the responses.
MOF, it was prompted by a question on another forum, by one who I am absolutely confident knows way more than I do.
When it comes to real, more in-depth experimenting, I leave that to you guys a whole lot more knowledgeable and much better equipped to carry them out.
BTW Tim - I did note that I run nitro in the OS engines for flying, and they do great.
I just didn't make note on nitro bench runs for some unknown reason.
Terry
AMA 249824
NRA Life Member
« Reply #7 on: March 09, 2015, 05:43:56 PM »
   I ran the 25LA on YS20/20 several times, and ran the 20FP on Cox Racing Fuel. It ran fine in either case. With the FP I got the point of diminishing returns pretty quickly - at a fixed (sea-level) altitude and condition, 5 to 10 made a big difference, 10 to 15 made fairly big difference a difference, 15 to 20 a noticable difference, and 20 to 30 relatively little difference.
   I have run my regular stunt engines, the RO-Jett 61 BSE, on anything from 5% to 30%, and the differences were always significant and pretty predictable. I also ran the compression to less-than-stock to "head button almost hitting the piston" and it made relatively little difference (once you got it started, which was very tricky with high compression, just because of over-choking). It was so insensitive that I don't even bother with it any more. The PA was a bit more sensitive but the effect was always entirely predictable.
   For the ST46, it *was* on the edge of something, and if you let the stock head gasket get compressed too much, it would let you know it was unhappy *very quickly*. But it ran great on 20-25-30% nitro with no changes. If I had to try running the ST again today, I would start with YS 20/20 and however many outboard fuel tanks were required to make it.
Offline Brian Hampton
« Reply #8 on: March 09, 2015, 10:11:15 PM »
My approach to some testing comes from a different angle because I don't use nitro at all but every engine I've ever run on zero nitro, ranging from several different types of Cox .049's up to a 1.20, have behaved perfectly with one flick starts and easy tuning from full 4 stroking to peak revs.
My testing involved changing compressions to get the most power from zero nitro which almost always means a fairly large increase because almost all current engines have compressions low enough for nitro to be used. Initial tests were done with an Enya 60X but, to avoid having to change shims or machining the head, I made a variable compression cylinder head so I could quickly alter the compression while still running. Starting with the same compression as standard and noting the peak revs (which happened to be exactly the same revs as with the original head) I kept raising the compression a bit at a time, check revs, increase compression, repeat, until it reached a point where there was no more noticeable increase in revs. That occurred at 13.5:1 which gave me a basis for other engines. The increase in revs, using an old square tipped Master 12x6 prop, from 11700 to 12500 indicated a HP increase of 22%. A similar increase in compression using a new head button on my Enya 61CXLRS gained 26% more HP with the 13.5x5 prop I use in my SV-11 where peak revs went from 8800 to 9500 but in actual flying where release revs are 7800 the main benefit was that the 4 stroking range was extended by several hundred revs and now gives a much nicer 4-2-4 run.
In a somewhat different area, I made a similar increase to my son's car engine and it then had the same performance (using 80/20 fuel) to other identical car/engines of other competitors using 25% nitro except he could run for 8 minutes on a tank to their 6 minutes.
