  • June 23, 2025, 01:00:48 PM
Author Topic: "The Golden Age of Stunt"  (Read 1141 times)
Offline Allan Perret
  • Proverbs
« on: December 28, 2009, 09:37:41 AM »
Does anyone know which issue of Stunt News had the article "The Golden Age of Stunt" by Randy Smith ??
Allan Perret
AMA 302406
Slidell, Louisiana
Online RandySmith
Re: "The Golden Age of Stunt"
« Reply #1 on: December 28, 2009, 09:58:11 AM »
May\June 2006
Online RandySmith
« Reply #2 on: December 28, 2009, 01:10:43 PM »
Hi Alan  it went something like this... less the pictures that were in PAMPA
Randy Smith
980 Winnbrook Dr,
Dacula, Georgia, 30019-2079
(678)407-9376
randyaero@msn.com
The Golden Age of Stunt, I’ve known we are living it; however, while at the VSC 18, this thought was solidified. The Golden Age of Stunt is Today. At no time in history did we have more planes, motors, props and all the stuff we use. It is amazing the amount of choice that is available to every stunt flyer.
From Laser cut Old Time and Classic kits to modern AAC motors to the light , super strong Carbon Fiber items that seem to grow out of the woodwork everyday.
The planes were absolutely stunning and comparing motor runs to 30 years ago, well suffice to say “no comparison”.
I have been asked many times lately to explain how to setup an engine for a good “stunt run”. All too often I see motors running backwards from the ideal. Four stroking up hill and breaking into a 2 stroke downhill, going blubbery rich on insides, screaming lean on outsides, etc, etc.
I would like to talk about the basics for setting up your engine to get a better machine. Someone once said a good stunt ship is 40% design, 60% motor. The performance of some of the airplanes at VSC proved this is true.
In a nutshell:
Remember the needle is for setting the fuel mixture, not for setting the plane speed.
The prop pitch is for setting the speed of the airplane.
The prop diameter is for loading the engine properly and getting maximum thrust from the motor.
Nitro is for controlling how much or how little break you have, this is to say how strong the motor will come on in the maneuvers. The other 2 items that work with this are compression and venturie size. This is not all there is to getting perfect engine runs. Many things work in
conjuction with each other to achieving this goal, and most everything I am going to mention affects the others to some degree or another. Please do not think of the following as an oversimplification, it is not. It would take a volume of text to try to explain all the relationships that one item has to another, this is just to try to add a little clarity, and to give you a place to start.
The 8 basics to helping yourself to a better engine setup are:
1. Engine: Pay careful attention to matching the engine to the airframe. Don’t overpower or under power your plane. Make sure your power plant is an acceptable weight for the ship it is in and matches well with it
2. Correct Fuel: Fuel is one of the most important things in tuning an engine. You must make sure that you have the correct oil type and percentage for the engine your using. For example Fox 35s, OS 35s, older McCoy’s and such need high oil content fuels 24 to 29% are common percentages.
Modern ABC and AAC engines will use much lower oil, 18 to 22 % percentages are the norm here. Nitro percentage is also key to getting the best from your power plant, There are so many ways to run stunt engines it is impossible to print anything but guide lines.
I have written many times about fuel. You can get a copy of my Care and Feeding of a Stunt Engine from the PAMPA archives
Typical stunt engines will use 5% nitro in cold weather going to 10 or even 15% in hot months. You can get in trouble using, say 15% in January, this setup would need 25% or more to be the equivalent in August. So unless you really have this working it is best to setup your engine for lower nitro in cold months and higher nitro in hot months. This will help keep the run constant thru out the year. Also it will help control power in your motor.
3. Correct Props: Props are also critical for achieving good engine runs; a prop needs to “load” the motor correctly without over or under loading the motor. It also needs to be the correct size and pitch to pull the airplane. This is an over simplication, but generally the diameter will be what you use to “load” the engine and the pitch will be what you pick to set the plane speed
Some of the things you will run into when over propping an engine are; hard to set the needle on the ground; the engine will unload a lot and go rich in the air; the engine will run hot, or not cycle very rapidly.
When under propping generally you will notice the engine will also not cycle correctly. They at times will just 4 stroke thru everything, sometimes going into a 2 cycle at weird times.
A properly loaded engine will use a prop that if running a 4-2 break, will come onto a 2 stroke a 10 O’clock and back to a 4 at 2 O’clock. There are variations on this; You can have a strong motor just beep 2 stroke at the tops of maneuvers, but you shouldn’t have one that 4 strokes uphill and switches to a 2 stroke on the downhill parts of maneuvers.
4. Needle setting: Don’t try to use the needle to set the speed of the airplane; the needle is for setting the fuel-air ratio that goes into the engine. Typical settings are so the motor will be in a very fast 4 stroke when in level flight. If you set the needle too rich it will delay the engine switching and make the engine come on late in the maneuvers. If you set it too lean, you can sometimes run the risk of too much 2 stroke and going sagging lean in the tops of maneuvers, killing your drive and over heating the engine. Once you get this set, you will have a little leeway in tweeking the needle in or out for conditions.
5. Airspeed: Most all planes like to fly at the airspeed they work best in, even exact or what is supposed to be the exact same design , will a lot of times want to fly at different lap times. Example: I have flown many SV-11s, at the same weight that fly at different speeds. Try to find the optimum speed for the plane your flying. This will depend a lot on the weight of the plane and also the power of the engines
6. Compression: Setting the correct compression for you motor isn’t a simple thing and will vary with nitro and prop size. Try to set the compression so when your engine hits into a 2 stroke it doesn’t come on too hard or too soft. This will work in conjunction with nitro and venturie size. Generally you will use higher compression for low nitro and lower the compression when using higher nitro fuels.
7. Venturi : Venturi size is one of the keys to get a proper switching 4-2, while not coming on too hard or too soft or too late or too early. If you are constantly accelerating too much when your engine cycles you may need to go down on venturi size. If you are not cycling much or have too soft of a break or a late break , you may need to open the venturi up a size or 2. This will work in direct relationship to nitro and compression.
8. Fuel Tanks: A large portion of engine problems I see are really not engine problems. They are fuel delivery problems that many times relate to fuel tanks, Tanks are maybe the most critical component of your power train. Make sure you have a solid mount, and a tank with no leaks or cracks in the tubing, inside or out. When in doubt I suggest trying a new tank, if there is a difference, you may have bad tank. Don’t forget to use a good filter and make sure there are no holes in the fuel tubing. It is also advisable to try to keep the tank as close to the engine as possible
These are just basic suggestion to help you tune your engine, and by no means covers it all. There are literally thousands of engine setups that would take volumes to cover.
Offline Leo Mehl
« Reply #3 on: January 03, 2010, 03:41:31 PM »
This is really good information from you Randy and I totally agree that there are a lot of setups and that tank problems are a big facter in the engine setup. I have seen a lot of beginners that have a terrible time with engine runs due to bad tanks. The problem is that a lot of people have a hard time believing this is a problem( I bought this tank brand so there shouldn't be a problem with it). Another thing to watch out for is storing your plane for long periods and not cleaning out the feed system befor using the the plane again. That means clean everything and take the needle out and wet flush the needle body with fuel or alchohal. Thanks for  this artical Randy. H^^ H^^
