  • June 21, 2025, 02:23:35 PM
Author Topic: Royal .25  (Read 1205 times)
Offline mike londke
Royal .25
« on: February 08, 2015, 06:23:30 PM »
LHS had a NIB Royal .25  ABC, Schnuerle, dual ball bearing. Would it make a good CL engine? Value?
Offline frank mccune
Re: Royal .25
« Reply #1 on: February 09, 2015, 04:52:41 AM »
     Hi:
      I am of the impression that this engine would be a great replacement for a Fox .35 Stunt!  Run them fast on a low pitch prop and have fun! The only problem that may arise is the matter of replacement parts if needed.
        Good luck,
        Frank McCune
Offline dennis lipsett
Re: Royal .25
« Reply #2 on: February 09, 2015, 06:41:20 AM »
    Hi:
        Good luck,
        Frank McCune
All  of the Royal engines are clones of OS engines. match the case up to the OS engine that matches it and you should have a chance at a repair.
Dennis
Offline mike londke
Re: Royal .25
« Reply #3 on: February 09, 2015, 12:22:32 PM »
Thanks guys.
