  • July 13, 2025, 03:56:15 PM
Author Topic: "Newbie" Fox .35 question  (Read 4154 times)
Offline RDJeff
« on: April 06, 2011, 02:52:36 PM »
Hey gang.  I have a Fox .35 that I bought about 25 years ago, built a plane around it, but could never get it to run.  It always started fine on prime, but wouldn't take off and run.  The plane got detroyed in a house move, and the engine has been sitting in a box since then.  I got it out last week, mounted it to a board, and ran into the same problem where it won't pick up fuel.  I tried the tank at different heights compared to the needle valve with no difference.  The spray bar is free of obstructions, and the crankcase is leak-free.  I want to use my old/new engine.  Can anyone offer pointers?  Thanks in advance!
Offline Jim Thomerson
Re: "Newbie" Fox .35 question
« Reply #1 on: April 06, 2011, 04:29:26 PM »
You may be getting leakage around the needle body. If so, put some Teflon tape on the needle threads.  If it were my engine, it would have a Super Tigre NVA in it.  Will it suck fuel when you choke it?  You may have to open the NVA several more turns.
Offline Russell Shaffer
« Reply #2 on: April 06, 2011, 05:00:01 PM »
Put a piece of hose on the needle valve intake side and try to blow through it.  If you can't, then things are plugged up. If it is clear then choke it and turn the prop both directions.  There is the slight possibility that it has a left hand crank and will only run "backwards".    If the needle is clear and it still won't draw fuel, check the backplate gasket.  If the backplate leaks, there is no way for it to get vacuum to draw fuel.  You should also make sure that the fuel line from your tank is actually in fuel and that the line is open.  Sometimes they get plugged up in amazing ways.  I have had every one of these problems including Jim's leaking needle valve body.  The engine will suck air before fuel if it has a choice.
Russell Shaffer
Klamath Falls, Oregon
Offline Bill Adair
  • AMA 182626
« Reply #3 on: April 06, 2011, 06:14:29 PM »
Hi RD,
The first thing I would ask (since you live pretty far north), is what is the outside temperature when you tried to get the Fox started?
The second question would be when did you buy your fuel? Hopefully, not when you bought the engine!  LL~
Third question is what kind of fuel, and what size prop are you using?
If your Fox engine is still new, and has only run a few primes, you can expect it to be hard to start. That will improve with a proper breakin, on the proper fuel. If you are not sure how to breakin a Fox 35, you should do a forum search for "Fox 35 breakin", and read that.
Generally speaking, Fox engines need lots of Castor oil in the fuel for breakin. You can NOT use R/C fuel!  n1
Sig and Fox sell the proper fuel, but you may be able to add Castor oil to what is available locally.
OK, you know that it runs a prime, so you are most of the way to a successful engine run!
When you say the spray bar is clear, does that mean it draws fuel when you cover the venturi with a finger, and flip the prop over several times? If it does draw fuel all the way to the spraybar, without a bunch of bubbles in the fuel line, it probably doesn't leak much air into the case.
Let us know more, and we may be able to help.
Bill (email address is in my profile)
Online Jim Kraft
« Reply #4 on: April 06, 2011, 06:50:18 PM »
Foxes will run pretty rich, so I would open the needle about 6 or more turns. I have seen this happen more than once where the needle just was not open far enough. The Fox instructions say 5 to 7 turns out on the needle, and I have seen where 8 works pretty good. Once you get it started, leave the battery on until you get the needle set. Also, check to see that you can not see either hole in the spray bar, if it is a 2 hole spray bar. If it is a  one hole make sure it is pointed down the venturi.
Online Robert Zambelli
« Reply #5 on: April 06, 2011, 07:46:24 PM »
Get a needle valve from Randy Smith.
After using his, I'm convinced that they're the best you can buy.
Grady Widener
« Reply #6 on: April 06, 2011, 11:48:03 PM »
Fox .35 can be a real kick, but if just getting back into the game and looking for easier handling and feeding, then you might ought consider procuring an OS la .46 or Brodak .40. If everything is not perfect, they will chug away a lot more consistently than the kinda persnickety Foxy gurl.  They will drink almost anything (because their cylinders are plated with nickel or chrome) and if get a lean run, are much more forgiving and will not go over the hill right away. When you learn how to make these run, then using an engine that gets hurt real bad if not handled just right, won't present the hurdles it might when you're just starting out all over again.
Shaken not Stirred,
Grady
Offline RDJeff
« Reply #7 on: April 07, 2011, 09:58:31 AM »
Wow!  That is a lot of responses!  Thanks to each and every one of you!
I had a Fox .35 when I was in high school, nearly 40 years ago, and it always ran great, and flew a number of different planes.  That is why I am baffled by this one.
When I tried to run it recently, the temp was about +45F, but I kept the engine warm in the house right up to the minute I took it outside to start it.  It took maybe 10 flips to fire, so it wants to run.  The fuel is some fresh 25% nitro stuff I picked up locally, then added castor to.  If my calculations are right, there is 20% castor in it, along with whatever synthetic the fuel came with.  Probably not ideal, but should be pretty close.  I'm using a 10X6 Master airscrew on it.  It will draw fuel when choked.  I'll have to check for a leaking spray bar.  The holes in the spray bar are both barely visible, so that they are basically perpendicular to the intake flow.  I never thought of turning the needle out so many turns, but it's sure worth a try.  The tank and lines are fine.  I drained the glow fuel out, filled it with diesel mix, and ran a couple of diesels on it within a few minutes of giving up on the Fox.  I'll try some of the ideas this weekend, hopefully something will work!  Thanks again!
Offline DanielGelinas
« Reply #8 on: April 07, 2011, 10:54:16 AM »
I may be mistaken but 25% nitro on the fox is way too much. I'm no fox expert, but from what I've read so far on these forums, 5 to 15% nitro is more like it. 5% for cold weather, 15% for hot weather.
Also, more importantly, your oil content for the fox is too low. The fox should be using 25 to 29% castor or a 80% castor 20% synthetic content to get to the 25 to 29% in the end.
My fox runs on brodak's 5% nitro, 29% castor. It also runs on brodaks 10% nitro, 29% castor.
Check Brodaks website to order online.
Also, I'm with the others on the needle valve thing: Try opening it more. If all else fails with the fresh 25-29% content oil, I would change the needle valve for an st (super tiger) version, they fit on the fox .35.
Also, on these first starts, an electric starter sure gets things started faster then by hand...
After a quart of fuel, my fox starts nicely by hand.
Good luck
-Danny  H^^
« Reply #9 on: April 07, 2011, 10:56:11 AM »
OH, and I forgot to mention, there is a great article in this section written by Randy:
"Fuel , GLO-plug and running tips"
-Danny  H^^
Offline Balsa Butcher
  • High Desert Flier
« Reply #10 on: April 07, 2011, 11:30:45 AM »
High castor percentage - Good info. Lower Nitro - Good info. Use an electic starter on a Fox - BAD  n1 info, most likely will push crankshaft into backplate causing damage.  More good info: Stuffer back plate (should be mandatory) Randy Smith Fox NV...likewise.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #11 on: April 07, 2011, 12:13:46 PM »
Pete,
With the stuffer plate, can one use the electric starter without running any risks ???
-Danny
  • High Desert Flier
« Reply #12 on: April 07, 2011, 01:34:06 PM »
I wouldn't. The stuffer backplate makes them run smoother but the crank shaft end can still be forced against it causing gauling. The electric starter issue is not exclusive to Fox 35 either, OS 35S' are prone to the same issue. Others experiences may differ but hey, you pays your money and takes your chances. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline RDJeff
« Reply #13 on: April 07, 2011, 02:39:47 PM »
I was mistaken on the fuel, it is a 15% nitro fuel, not the 25% I was thinking.  When I added the castor oil to the mix, that would reduce the percentages of all the other components, so that 15% would be lower, maybe 10%.  I'm thinking the amount of castor I added should be fine, the amount added was 20% of the original fuel quantity.  Or is this engine like a diesel, needing a lot of castor to get compression where the synthetic doesn't really help.  I couldn't find the oil content on the original fuel, so don't know how much there is in the mix.
« Reply #14 on: April 07, 2011, 02:42:42 PM »
  15% is fine, and it should make it easier to start. I wouldn't be too scared of 25% as long as you work up to the break-in. I used to prime my Fox with Cox "Blue Can" when I was running Fox Superfuel, makes it kick over a lot more energetically.
« Reply #15 on: April 07, 2011, 04:46:53 PM »
What Brett said on the nitro.  Werwage and Wooley (along with many others) frequently used 25% nitro. ;D
Sounds like the NVA isn't open quite far enough, or there is an air leak.  Check that and get it "wet" through priming with the finger over the venturi.  With it upright on the stand, it will not flood real easily.  I'm with the others, electric starters on the old engines can cause problems, especially with a "heavy hand".......
Big Bear
« Reply #16 on: April 07, 2011, 05:11:48 PM »
  Although if you do it for long, I would suggest finding a Randy crank! Either that or carry about half a dozen stockers.
p.s. you might be surprised what these engines will run on. I recently assisted some kids of a friend of mine with an experiment where they ran a 20FP (the one that David and I flew for 547 and 542 points, respectively, in P-40 one time) on glow fuel mixed with either gasoline, or with vegetable oil. Even 50/50 gas and glow fuel ran, although with only 9% oil it wasn't going to do it for long, and it got *very* hot. It ran fine on 70/30 glow fuel/Wesson Oil with essentially no power loss, and if we had opened up the spraybar holes, it would have at least started on 50/50. As it was, with the 50/50 fuel/oil was too thick and I ran out of needle adjustment before I got it rich enough to run.
« Last Edit: April 07, 2011, 05:29:09 PM by Brett Buck »
« Reply #17 on: April 07, 2011, 06:42:06 PM »
There were some Fox 35 needle valves around that required that they be open 8-10 turns for starting. I remember this from the instructions of the first Fox I had in the early 80's. Might you have one of those? I don't know how to identify them by looks, but I know the needle was flat on one side.
« Reply #18 on: April 07, 2011, 10:21:12 PM »
     A lot of them are like that. I think the issue is where the threads end relative to where the wedge starts. I used up A BUNCH of stock needles in the late 70's/early 80's and even from the same batch, one would need 5 turns, and the next would need 8. Only about 3 out of 10 of them worked properly in any particular spraybar. A particular spraybar needed a certain type of needle. And where the flat wound up relative to the holes also made a huge difference, not in the number of turns required, but in exactly how the 4-2 worked and how evenly it ran.
     This brings back many nostalgic memories of sitting out in a hot parking lot for hours on end trying various combinations of randomly-produced Fox parts (and fuel and tanks and props and glow plugs) to see which ones ran properly. It reminds me of the murderous blinding rage and dreams of finding something better and then taking every Fox 35 I saw, placing it gently on a blacksmith's anvil, and smashing it into individual quarks and gluons with superhuman blows of a 10-lb-sledge. Ah, good times...
« Reply #19 on: April 08, 2011, 12:33:11 AM »
Whoa! Although I've thought about doing the same thing many times, I just knew there were too many Fox lovers on this forum to ever put it in print like that.  :o
Offline kenneth cook
« Reply #20 on: April 08, 2011, 03:16:39 PM »
     I would say considering the engine is new for the most part, I think a few things should be addressed. The engine has sat for several years if I read that correctly. I would check to see if that conrod is floating freely on the wrist pin using a small allen wrench to get behind the rod and work it back and forth with some oil. While the backplate is off a new gasket should be in order due to that one more than likely getting ruined when you remove it to check the rod and also it has been squished for a long time. I generally lay the case on a piece of glass with 400 sandpaper on it and a bit of wd-40 as a lapping oil and work the case flat for the gasket area. You would be pretty surprised as to how untrue that area is. If the backplate isn't sealing your not going to draw fuel. You claimed no crankcase leaks so I will take your word and let you decide whats best to do. Just remember its very easy to overtighten the backplate and distort the ears. I would also highly suggest not only on the test stand but also once in the plane to wire tie with copper wire your fuel tubing to your fuel barb on your spraybar. This will eventually come off especially once the tubing really gets oil soaked. I would orientate the holes on the spraybar so that when looking down your venturi that you just start to see both holes looking straight down on them. I would also suggest a inline fuel filter on the test stand as to not get major bubbles causing erratic and lean runs. Although the needle valve is poor as most claim, it works with a few tricks. I'm assuming that your needle has a flat on one side because of the time frame you described when you purchased it. . If so, this needle doesn't have to be entirely screwed out to work. I would place a square clean cut piece of tubing on your needle about 5/16 long and then screw it into your spraybar. If need be, you could cut a few pieces of tubing smaller allowing you to screw your needle in more. This is the probable reason why its apparently not drawing fuel. After that , I would start it up as I see no reasoning why it wouldn't run. We cut our Fox needles so they don't get broken in a inverted landing. You clip the round knurled knob off and bend it over into a J shape. This allows one finger adjustments while the rest of your hand is holding the plane and this advice probably just saved you $20.00 in broken needles. The newer tapered Fox needles  are barely screwed into the spraybar to get them to work correctly hence the need for a larger piece of tubing on it. The older spade style is no longer available and the new tapered is the replacement. Bob Z stated above about the Randy Smith needle and spraybay. This is a well designed and affordable option. I would say that there is no needle out there as nicely made as that one and its a direct fit having the center area the same size as the stock Fox unit. I usually use a Master Airscrew 9x6 on break in and I don't break mine in on a rich run but a steady two breaking back and forth. These methods work well for me maybe not for everyone so good luck.  I surely don't suggest Brett's sledgehammering method. Ken
« Reply #21 on: April 08, 2011, 03:32:01 PM »
  It was just a wonderful nostalgic dream. My recommended solution to almost any Fox 35 run problem can be found here:
http://www3.towerhobbies.com/cgi-bin/wti0001p?Q=1&I=LXPUE2&P=3
Offline Chris Wilson
« Reply #22 on: May 02, 2011, 07:19:38 PM »
You know, I actually clicked on the above link looking for a shrine of knowledge on the Fox 35 - boy was I mistaken!
Nice humor though Brett.
MAAA AUS 73427
Offline RDJeff
« Reply #23 on: May 03, 2011, 09:29:52 AM »
I tried all the solutions, 6-10 turns on the needle, made sure the spray bar was sealed, still no run.  It fires right off, and quite eagerly, but only runs on the prime.  The needle is one of the chisel types if that helps date the engine.  I gave up and bought an O.S. .25.  I'll try the Fox again some day when I have more time.  I wanted to break it in so I'd have an engine for this season.
« Reply #24 on: May 03, 2011, 03:41:12 PM »
  Actually, that link is about all you need to know about the topic! So I contend it *is* a shrine of Fox 35 knowledge.
