  • June 25, 2025, 04:33:18 AM
Author Topic: ST 51 Nobler, Smoothie  (Read 4540 times)
Offline Allen Eshleman
« on: February 01, 2011, 01:15:18 PM »
I have Nobler and a Smoothie.  They have both flown marvelously with a B-40.  I currently only have one B-40 or 40 sized mother.  I have a ST 51 which runs very well but have no plane for it.  Is the ST 51 too much of a motor for these two planes?    I know that front reconstruction would be necessary for make the motor fit.
Also, will both the Nobler and the Smoothie do the "pattern"?  I've only advanced so far to vertical 8's.
Offline Gene O'Keefe
Re: ST 51 Nobler, Smoothie
« Reply #1 on: February 01, 2011, 02:17:08 PM »
The most I would stuff into the nose of a Nobler would be a LA .46   -- The .51 Tigre would be to much power plus the additional weight would offset the benefits. If it flew great with the B.40, I'd stick with that. Just my 2 cents worth.
Gene O'Keefe
AMA 28386
« Reply #2 on: February 01, 2011, 02:41:52 PM »
What Gene said.... H^^ Steve
Offline Balsa Butcher
  • High Desert Flier
« Reply #3 on: February 01, 2011, 03:58:34 PM »
I've flow both Smoothies and Noblers with: OS-35S', Brodak .40, FP-40's and LA 46. The nice thing is that if you set up your plane for one, all of these will fit. Brodak 40 is perfect for either Smoothie or Nobler, LA-46 also, especially for the Nobler. ST-51...save it for a larger plane. And yes, either plane will do the pattern, quite well in fact.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #4 on: February 01, 2011, 04:08:13 PM »
Thanks Guys,
       Does the extra power of an LA 46 make either these planes fly better than a B-40.
I thought that the ST 51 was too big and heavy - drinks more fuel too.
  • High Desert Flier
« Reply #5 on: February 01, 2011, 04:56:00 PM »
IMHO I'd put the B-40 in the Smoothie and the LA 46 in the Nobler. As far as one being better than the other, that is more airframe design than the engine in this case with the Nobler having the edge.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Robert Zambelli
« Reply #6 on: February 01, 2011, 07:11:33 PM »
I decided to do something really different with my 1951 Nobler. I put a 1951 Fox 35 in it.  LL~   LL~
Guess what. It flies PERFECTLY. Weighs 44 ounces and it's a dream to fly.
Just my opinion but I still feel that this is the perfect combination.
Bob Z
« Reply #7 on: February 01, 2011, 07:29:54 PM »
I had a Fox 35 in my Nobler, in fact two different ones.  The first one came with it - out of the flea market shop - where I bought it.  It is very nicely built but recently I flew the outside wing tip into a light pole - ouch!   My brother is putting it back together - wing in two pieces and fuselage in two pieces.   The first Fox 35 - an old one - with one bolt hole broken off the case - it ran fairly well.  Then I got one of the newest editions - it ran well but I never felt comfortable stunting with it.  It came in on me.  Finally I figured that problem out but by then it had a B-40 on it - and then I wrecked it.  I accidently hooked it to 70 ft lines instead of 60.  Well!  However, I was just getting comfortable to do stunting when it collided with the light pole.
I may have a spare Fox 35 somewhere.
Also,  what is a good plane for the the ST 51 - a Pathfinder?  Cardinal?   Vector?
Thanks again.
« Reply #8 on: February 01, 2011, 11:24:07 PM »
Hi Allen,
A good ST G.51 will fly a pretty big model with no problems.  If you're in the ARF market, I would suggest a SV11.  I had a scratch built foam wing one that really flew well with that engine. y1
Big Bear
« Reply #9 on: February 04, 2011, 07:16:42 PM »
I disagree..
The question of " Is the st .51 to much engine for a Nobler " I can answer.
As far as power I'd say no - Would I put one in ? the answer is also No. - For the reasons below.
SPECS:    Bore:   23mm (.905")
          Stroke: 20mm (.787")
          Weight w/o muffler:  313g (10.98oz)
          Weight with muffler: 459g  (16.2oz)
I regularly run ( and have won multiple National competitions in Classic Stunt ) with a 1951 Nobler powering it with a Stalker .61
yes STALKER .61 - So that is far more power than your St .51 - The problem I see for the ST 51 is weight.
You can see the specs show that the weight is 459 G with the muffler - and the muffler is side mount.
2 Main problems with the ST 51 is weight and weight balance.
The muffler weighs 146 Grams Engine 313 Grams Total : 459
Having THAT much weight makes balance for a little nobler extremely difficult - As I mentioned I run the Stalker .61 and more specifically the EX Lite edition. with rear exhaust light weight muffler.
Specs on that are : Muffler weights 45 grams and Engine 315. Total : 360 ( Thats 3.4 Oz LIGHTER )
The 2nd issue is the weight balance point. With a rear muffler the total weight is actually moved back further by at least 8 - 10 cm.
So not only with the rear exhaust is the muffler lighter but its moved further back.
This makes a huge difference to the balance point. Overall the weight is moved too far forward with the ST 51 - you have a huge amount of weight in a very concentrated forward balance point.
Even when running a Tuned pipe, you have the weight of the Pipe, but its so far back behind the CG that is doesnt matter to much - compared to having that all located within the front few inches.
So to much power ? God no.. Ive even run the Stalker .66 in the nobler. If your around at the US NATS - I will have a new classic model with stalker .61 with special Ultra light Custom muffler - flying in classic so you can make your own assessment of if its too powerful.
To give you an idea the Stalker .81 is still lighter than the St 51  y1 - I dont have the specs infront of me but i suspect the PA .75 with tuned pipe would also be lighted than the ST .51 w/muffler.
I've had several noblers ( 10 + ) with everything from Veco .29 Upward..  im not advocating everyone putting an engine of my size inside. I do agree that there is alot of engines Like the Brodak .40 that will run it PERFECTLY. and the Aero .36 works exceptionally well.
Others have flown my nobler and EVERYONE has said - Its so easy to fly - Someone said " its like cruzing down the freeway in a Musclecar with modern engine and suspecsion. Just tickin along. With that much power - Ive flown it as slow as 6.5 second laps and make it REALLY slow but still drive slowly through the pattern.. Or you can dial in your speed as you see fit. Such a wide window of operation.
I personally have mine set up like other notable experts fliers have current CLPA models setup - Big bore engine, low down thumping power constant 4 stroke, constant speed. - Simply put results speak for themselves - Lots of torque with reliable power, reliable manouver speed over various conditions and various atmospherics.
Over kill ? Possible but as Randy smith says we now live in an age where we know how to set up engines for run characteristics that are favorable to Stunt. - Be it classic or CLPA.
« Last Edit: February 04, 2011, 08:16:06 PM by PJ Rowland »
« Reply #10 on: February 04, 2011, 07:31:31 PM »
Just build the NOBLER twice size . The Stock G-51 starts working O.K. flying 70 Oz. plus.
IF you let it rev . Book says 11x6 , which will be a bit quick even on 70 ft lines .
Cut a big prop down to get a bit of blade area to absorb the H.P. the radio versions 1.6 @ 16000 odd.
They sound a bit funny on a 10 x 4 3 blade but go pretty good .- locked in !? gotta G 40 for that prop.
now.
Krikey. a FSR 25 will fly a nobler,even a FP 25 if its light.
Weight is the enemy of aerobics, or is it loading.wot if its windy.or is that the pilot.such is progess .  S?P
« Reply #11 on: February 05, 2011, 06:58:59 AM »
Twice the size isnt the answer.. the engine is too heavy as it is..
« Reply #12 on: February 05, 2011, 07:40:31 AM »
Very interesting and informative discussion.  What are some other planes which would fly well with ST 51, beyond the SV 11 which was already mentioned?
What planes are being flown competitively with an ST 51?  This is the Chinese Version stock.  a bout 35 flights - runs great!
Offline James Mills
« Reply #13 on: February 05, 2011, 08:37:19 AM »
I ran the ST 51 on my Magnum and then for several years in my Shark 45 (at 66 ounces or so) and it flew very well.  Compared to other motors I don't think it's to heavy.  I toyed with the idea of putting it in a smaller airframe (say 630-650) but have never got around to it.
James
AMA 491167
« Reply #14 on: February 05, 2011, 07:01:04 PM »
Would an ARF Legacy work with the ST 51?
« Reply #15 on: February 05, 2011, 07:32:09 PM »
True.. compared to a YS .120!!!!!!!!!!
Its just the weight - not the power
St51 :        459 Grams
Stalker .81  423 Grams
Im using the stalker as an example becasue ive got one here to weigh and I cannot find any weights on the PA engines - I suspect they are similar. - However if you must persist and build something an SV 11 would be ideal
« Reply #16 on: February 05, 2011, 08:00:45 PM »
HI Allen,
Yes, I feel it would.  For less that "international competition" it would work in a Impact ARC from UHP.
Since you are dealing with ARFs/ARCs, those three would be the best choices I think.  The Strega ARF/ARC might be a bit much for the ST G.51 but Windy retrofitted a couple of his planes with one when they first came out.  We had some videos of him flying pretty decent patterns with the Red Baron, about the size of the Strega.  he also worked with them on a pipe.  The key to the ST G.51 is that they are a higher rpm engine than the ST V.60 small case.  The ST G.51 likes a 12" prop with about 4 1/2" pitch, or up to 5" pitch max to really make use of the power.  But I have seen a lot of ST G.51s be competitive (very) in planes under 70oz.  They are NOT a PA .51, nor a ST V.60 (won't really swing as big a prop) but they are stronger than most say.  Just don't have it retimed to do the *6" pitch slow 4-2 run*.  It usually doesn't work well since the power is lost.
I have never seen a Score or a T-Rex, but I am guess the T-Rex would be pretty good with a ST G.51.
Big Bear
« Reply #17 on: February 08, 2011, 05:48:49 PM »
I thought the G-51 was 313 grammes minus silencer ?
If you like the hair on the back of your neck bristle ,
and the rest to be on end ! Build a 52 in Span Martin Baker MB3
to Al Rabes aerodynamic Criteria . If it weighs 2 Kilo it will be
a very intresting exercise . In a 20 Knot wind the houglass
and cloverleaf are ' intresting ' .In a similar manner to being
stuffed in a drag race car , hands tied , with the throttle stuck
full on .
That said , it flew acurately and consistantly , couldve done
with the rudder connected as per his mightynesses manner .
Will do another LIGHTER one for an old Max 40 ( I hope ) .
Italian Luchiano Compesstella did a 4 stroke thing in 1980 (enya)
I pirated the Airframe and did as a Spitfire . Similar weight (oh dear)
but very competant happy plane . Had a few obscure mods to controls
and was NOT scarey in any wind I flew it in ( 20 Kt. +).
Unfortunately the funny granching noise wasnt the Engine.
Twisting the elevators neutral once SPLIT the 2.7 wire pushrod to E. horn.
3rd flight with a Irvine 40 RE & 10x4 3blade prop, it disconected coming out
inverted from the wingover, dropped its nose from level.
The second correction the flaps acted as elevators as well .
The outer dihedraled wing was a bit second hand as was prop.
Nice trench in the field too . . .
Gotta do another 1 or 2 of them too . . . amongst other things .
Just one more !
If your useing a G-51 Id use adequate glue as you tend to get
some Forces at Work , at times. Great Fun if your not churlish.
I have plans for these monsters.
« Reply #18 on: February 08, 2011, 06:08:43 PM »
HI Matthew,
I have always been very happy with my ST g.51s.  They are not 100% stock, but close enough.
I am starting a KA 10 next, and it will have the ST G.51.  It should come in under 60 oz, and that engine will pull that like no one's business!  The "BEST FLYING" combo I think I ever had was my USA-1 700 sq. in. and 54 oz. RTF.  Overall, it was just as EASY to fly, and went exactly where you pointed it.  Smooth upright and inverted but a super nice turn, and flew "on rails".  With a 4 1/2-4 3/4 pitch 11 1/4" 3 blade it was as awesome as is allowed! LOL!!
How's you F-4 Phantom doing, Matthew?
Big Bear
« Last Edit: February 09, 2011, 11:26:44 AM by Bill Little »
Offline Brian Hampton
« Reply #19 on: February 08, 2011, 10:51:27 PM »
My G51 weighs 380 grams with its home made adaptor, Bolly CF Aftermuffler and silicon connector tubing. Using zero nitro fuel and a 12x5 Zinger prop it had more than enough grunt in a solid 4 stroke to haul around an 810 sq/inch 59 ounce model with ease (go on, work out the wing loading :)). The engine itself is totally box stock (Italian) standard.
« Reply #20 on: February 09, 2011, 11:26:06 AM »
Hi Brian,
I was "sold" so to speak when I first used one.  It was on my 1st SV11 that weighted 64oz.  I flew at Norfolk early in the model's life and the wind was pretty bad.  The plane didn't really mind!  A good ST G.51 will pull a pretty large model around just fine for most of us.  Maybe not enough to use at the World's (different needs for that I guess!) but good enough for local duty at least.  Not as strong as my PA 51, though! LL~
I remember Henk De Jong and his "little bit of *PEARL* don't ya know" at the World's in Muncie, 2004, which was powered by a ST G.51.  We talked about it a good bit.
(I just edited a typo in my KA10 reference above! LL~ )
« Reply #21 on: February 09, 2011, 11:28:34 AM »
BTW:  Tom Dixon put one of his ST G.51 in his early orange and black T-Bird II.  He flew it really well.
Big Bear
  • High Desert Flier
« Reply #22 on: February 09, 2011, 12:33:00 PM »
Since it was brought it up, I remember that airplane as having a modified Royal 40 when Tom won an early VSC with it, not to say that he also didn't try it with a St-51. However, that version of the T-Bird had a 610 square inch wing, much larger than the 550 squares of the Nobler.
He did design a .51 sized T-Bird that looked identical to the 59 T-Bird but had a 630 square inch wing. It was never published but plans are available.  Built one, wing was warped, never flew right, cured me of my T-bird fixation. 8)
« Last Edit: February 09, 2011, 12:51:01 PM by Pete Cunha »
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #23 on: February 09, 2011, 03:23:04 PM »
Hi Pete,
Since Tom is a "local" so to speak, I have a lot of his older plans.  The .51 size T-Bird is one.  Dale Barry had a very nice flying one back in the pre fire days, and I almost built one when I saw his.  Of course, Dale's was white and PINK!  And, IIRC, he built it with an up right engine and turtle deck ala the first T-Bird, but other wise built form Tom's plans.  ;D
Big Bear
  • High Desert Flier
« Reply #24 on: February 09, 2011, 03:37:14 PM »
Hi Bill, thought I had a picture of mine on file but guess it got deleted. I think the tips are off and as a result it needed some major trim tabs and never did track well. Undoubtedly Tom's flew much better. The best flying sorta T-Bird I have built was Tom's "Phoenix" as published in Model Aviation. Like to make another one some day.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #25 on: February 09, 2011, 03:46:19 PM »
"My G51 weighs 380 grams with its home made adaptor, Bolly CF Aftermuffler and silicon connector tubing."
Thats still heavier than a modern .61 - this was my only point.
  • High Desert Flier
« Reply #26 on: February 09, 2011, 04:21:32 PM »
Regardless, most folks, especially those just getting started in this sport (read initial inquiry) would be better served with a more modest engine..ie B-40, LA-46 in these particular models.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #27 on: February 09, 2011, 04:25:49 PM »
I dont disagree with running a B 40 for that model either for a beginner.
« Reply #28 on: February 09, 2011, 07:36:26 PM »
The "tips" (actually the outboard one) was what has shelved Aaron's Brodak T-Bird for now.  It was pretty hard to find, but that is a "big" wing tip! ( I count it from the end of the flap on out) ;D
  • High Desert Flier
« Reply #29 on: February 10, 2011, 01:29:10 PM »
Say Bill, I found the picture of my king size T-Bird. I ought to just cut off the tips and square off the wing...but then it wouldn't be a T-Bird. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #30 on: February 10, 2011, 04:07:14 PM »
I'm really digging the looks of that one, Pete!
Big Bear
