  • June 13, 2025, 11:13:52 PM
Author Topic: core house products  (Read 18810 times)
Offline Greg McCoy
  • flying tiger B24 gunnery school patch Laredo
core house products
« on: September 04, 2010, 08:40:31 PM »
The Gotcha 550 is my most fun flying planes in my shed. With Thunder Tiger  Pro.25 they do about 80. On flying days the Gotcha's go first, and the Shoestring has to wait.
AMA 77370
Re: core house products
« Reply #1 on: September 11, 2010, 03:12:11 PM »
Sparky was kind enough to put the Core House into the vendor's corner.
We've got a number of planes on the roster:
ARF Speed Limit plane, the Gotcha SL.  This is a purpose-built Speed Limit plane designed around a 25 engine.  Span 48 in.  460 squares.  Bladder fuel system.  Airframe weight is 10-11 oz.
F2D15a  A competitive ARF F2D plane with all the advantages of a foam wing.  Rugged 3-spar construction- top and bottom, plus leading edge.  Easy maintainence and easy repairs.
The Streak III Stunt trainer.  Light weight, innovative foam core fuselage.  Laser cut parts.  Easy build and easy repairs.  Available as a kit or as an ARF.
WW-II combat and sport.  Wing cores and plans for many near-scale fighters.  Pair up for a great demo, or just fly for fun.  P-51D,  FW-190, P-40D, Hellcat, Wildcat, Zero, Airacobra, and more.  Scaled to 48 in. span.  The wings and tail are at ~1.4 in/ft,  the fuselage at 1in/ft.  Wing areas vary from 430 or  squares to 500.  Light enough, at 25-28 oz. RTF to fly well on a 25.
on-line at http:home.earthlink.net/~philcartier
