  • July 12, 2025, 09:08:45 PM
Author Topic: New!!! Half Lite Combat/stunt wing  (Read 13168 times)
« on: November 04, 2020, 07:42:43 PM »
This wing was designed for Half A Combat(TeeDee and similar performance plain bearing engines)  Span 31.5 in.  Area  200 sq.in.
The original HalfLite was 32.5in. span, if I remember correctly.  The current cores are cut, 2 sets in a block, with about 19in length(96in sheet/5)
Root thickness is about 1.1in  about 15%.  It's been used for 1/2A stunt,  Half A Combat, some racing.
Cut from 1lb/cu.ft. white EPS(styrofoam) specified for One Coat stucco siding- strict limits on density variation, pinholes, density variation.
2 sets in a box  $25
4 sets, loose pack packing, cores only-  $35
plus shipping- between $10 zone 1 up to $16.50+/-
picture shortly
Guess it's no longer shortly.  I'll see what I can do.
« Last Edit: September 04, 2021, 07:23:53 PM by phil c »
Offline John Given
Re: New!!! Half Lite Combat/stunt wing
« Reply #1 on: November 08, 2020, 06:22:33 AM »
Looking forward to this!
