Speed,Combat,Scale,Racing => Combat => Topic started by: Tim Chenevert on February 03, 2018, 03:55:46 PM
I have a very old Sneeker with a Super Tigre G21 35 on a pacifier system. I broke the wooden prop that was on it so I put a wooden 10x5 prop to start it. Finally got it started and excited to fly it now. I would like to put the correct propeller on it but have no idea what this plane should use. The old prop diameter was 8” but was told this was a “slower” prop. I was also told the engine had been internally modified but not sure what has been done. It was running a rich 4 cycle at 5500 RPM. I have not tried to lean it because of the prop change. Any advice would be greatly appreciated. Tim
Back in those days 8-8s, 9-7s and 9-6s were commonly used on G21 Tigres.
So the 10-5 is too big? Maybe go with a 9-6 for first flight? Tim
My 2 cents. The G-21 will run pretty well with the 10x5 and an APC 9-6 will be lively. TS
Thanks guys for the info! May try to start it again today. I am hoping to fly it next week and can not wait! Right now I am using Omega 10% fuel, the pink stuff, with castor to bring it up to 23% oil total and nitro is approx 9%. Origionally it is a 30/70 castor/syn mix and 10% nitro. Does this sound about right? This is all that is available from my LHS. Thanks again, Tim
With a bladder system, under-revving the engine will cause a lot trouble. The bladder gives constant fuel flow, so if it bogs down in turns, the engine will rich out.
So run a 9/7 or less.
Odds are, if your G21 ws used in combat, it was probably abused with bad fuel. So at this point the damage has, most likely, already been done.
I flew Riley Wooten designs in the 1968 Nationals at the Olathe, Kansas Naval Air Station........(Vampires and Voodoos at that particalar contest) using the Super Tigre G-21 .35 engine and took home the 5th place trophy. Of course Riley won first in the Nats that year, flying his Flite Line Vampire and a Fox .36x BB. A Canadian flier, Pierre Seguin, flew against Riley for first place and after getting a good streamer trimming, he went home with second place flying a Sneeker with a Super Tigre G-21-35. ...... Anyhow, I found that on Wooten designs, the G-31 .35 performed best for me with a 9/7 paddle blade Top Flite prop, a pacifier pressure fuel system and Missile Mist fuel. I suspect that Rev-up 9/7's would also work well, if you can find them. I also had, in the 1960's, three of Riley's Flite Line Sneekers which I flew with the Fox .36x BB engine, pacifier fuel system, Missile Mist fuel and the Top Flite 9/7 nylon prop and that combination worked well....won a few trophies in local contests around the midwest. .... On the one winder that I built back then, I ran the Super Tigre G-21 .35 engine, pacifier fuel system, Missile Mist fuel and a 9/6 Rev-up prop....which worked extremely well. Experimentation is the key to finding what works best for you. D>K H^^
We ran Rev-up 9x7 combat special prop. They were actually a 9x6.5. Had the red tips on them. Today I run a nylon 8x8 on everything 35 in nostalgia combat.
if u can find a Rev up 8 1/2 /6 1/2 wide blade, it works great on the Voo Doo and Sneeker
Brodak has quite a number of rev up props. They are in back storage so you have to ask. TS
I built my one and only Sneeker in 1970 . Silk and dope, LS Fox 36xBB and pacifier. Never used in competition .( not flown 1975 to 2008). At the 2008 AMA Fly-IN, took it out and on the second flight, the original nylon bell crank broke in half , so it was curtain time. Just so that you know, it was pull tested. Even today, I consider my Sneeker to be the most stable combat ship I've ever flown.
Well guys today I was flying my Twister and I think I have the bugs worked out of it. Seems a new glow plug and a new mix of fuel was all not took! So I had brought the Sneeker with me and I asked Perry if he would hold it for me and he said he would. I fueled it with 1 1/2oz and clamped it. I still had the 10x5 prop on it but bought a 9x7 this morning but didn't install it. Anyway, I started it, walked the lines out and signaled Perry to let go. Wow! What a plane. The flying wing is awesome compared to my Ringmaster and Twister! Very stable and Perry said the ST 35 sounded like a piped engine. It is a very fast plane to say the least. I had to leave after that first flight but look forward to flying the Sneeker again....with the 9x7 prop. I do plan on repainting and recovering it in purple and gold. I even have a name for it now, "Tiger" because it felt like I had a tiger by the tail! Lol Does anyone know if there are any kits still available? I would like to build another one. Tim
Okay... then which year was it that Riley won with a Vampire and Canadian Al Baker finished 2nd flying an ST powered "Eegad"? I thought Riley/Al's match was at Olathe in 1968?
Andre
Andre
Nope............Riley won in Open Combat at the Nationals in 1966 which was held at Glenview Naval Air Station flying his Flite Line Vampire (classic Wooten trademark finish - white trimmed with red). He was running Fox .36x BB's. I was at Glenview in 1966 and flew in that event. Unfortunately for me, in the first round, I flew my Wooten Vampire / Fox .36x BB against a United States Air Force Team member and he took off my stabulator. He got back in thee air and since he was ahead on points ....... he won and effectively reduced me, after that first round match, to a spectator. It was here that Riley encountered the Canadian Al Baker in the match for first place. The year was 1966. The place was Glenview Naval Air Station, Chicago, IL. There is a well known photo of Riley and Al taken just after the match which was published in one of the model airplane magazines of the day.....I think it was American Modeler, but I am not sure. Al Baker and Pierre Seguin were both Canadian and both flew against Riley Wooten for first place in the nationals..........Al Baker went against Riley in Glenview, IL in 1966 ........... Pierre Seguin went against Riley in Olathe, KS in 1968. Both Canadians went down before Riley's guns and Riley went home with the hardware. ....... I know .... I was there ! D>K H^^
The Flite Line Sneeker was quite stable and flew like a sports car drives. I liked Sneekers, but I like Howard Rush's Nemesis II the best over all....one heck of an airplane ! D>K H^^
Ah, so it was '66 at Glenview!
As a kid I remember seeing the picture of Riley holding his Vampire and shaking hands with Al and his Eegad in that magazine. Sure would like to find that picture again. In fact, finding the entire magazine would be great IF I knew which one it was.
Thanks for clearing up my corn-fusion.
Andre
Umland makes a beautiful kit. Flys great! TS
Tim, Bare sells the plans at:
http://www.controllineplans.com/frameset2.htm
If I recall correctly, Riley or Marvin Denny once posted that the original Sneeker had a 3" or 4" greater wingspan, but the kit model was shortened due to packaging and shipping reasons. The extra span helped turning ability and can be added in the center section. Because the G21 was heavier than the 36X BB, you would want to build the extended boom version.
Tim I have an original Flite Line Sneeker kit if your intrested
Has some one contacted Riley on this stuff? In fact didn't he post some recollections of his endeavers on here? I may search later if some one doesn't beat me to it. HB~>
Fred, I sent you an email. Tim
John, I sent Riley Wooten a PM a few days ago but haven’t heard back. Tim
I have an Umland Sneeker. VERY nice kit... wrong nose pod in regards to a historical replica. Umland's uses the stubby "Nemesis" type nose pod that didn't come around until after the original Sneeker era. If/when I build my Umland Sneeker, I will be using a longer nose pod like they were originally back in the early/mid sixties.
Admittedly, the above is a very small "non issue" (gnat/camel type thing)... but I'm sometimes a bit anal about things. LL~
Of course, YMMV!!
Andre
You can try to contact this seller on eBay, He use to sell the Sneeker kit and many others.
Al
https://www.ebay.com/usr/henry36912
I think I got the last kits that Henry Shun was hand cutting. Lives in Hawaii. I have not received any E-Mails from him for some time. My favorite planes from him was the smaller Sneeker and Bosta. Both fly great with Fox .15 Schnuerle on suction. According to search he is 84 years young and still alive. D>K
Fred, I sent you an email today. Tim
Got it Tim we are on track
Awesome Fred and thank you very much! Tim
I have decided to build the Sneeker so I can fly it more because my other one is so old. I am looking for advice on fuel tank setups other than the pacifier ( which I think is cool ) so it will be easier to fuel up. I see on the plans a Veco T-21 modified tank is recommended but I am sure they are hard fo find and have rust. So a modern recommendation? Also a good choice for an engine? Thanks, Tim
Brodak has tanks. Brand new and nice. You can even get a tank kit and plumb it yourself. Motor. WOW! Anything from a stout .15 to a .40. I prefer vintage therefore my Sneeker has an LS Fox .36xbb abc. Part vintage anyway! Ts
PS 3oz. should get you dizzy enough
Brodak has a do it yourself tank that is 1”Hx2”Wx3 1/2”L number BH-784 that looks like it can be plumped like the Veco T-21 on the Sneeker plans? If I am reading the plans right, it gets pressure from top tube and fuel flow is from bottom tube on tank? Tim
Hello Tim, here is a photo of the syringe that I use. It makes refueling a pacifier or a bladder a piece of cake. For convenience you would want to solder about a 2" extension piece of metal tubing on the end of the spout, because it is short. These syringes, made by Nasco, are available at farm co-ops and veterinarian supply stores, and I'm sure they can be found online. They cost about $5 and last forever, and hold about 2 1/2 ounces of fuel. My unsolicited advice would be to stay away from metal tanks on combat ships. Pacifiers and bladders generally provide steadier engine runs during high speed, high-g maneuvering.
Here's my Sneeker from one of Walter's kits. Powered by a LA 40 with a Red Cap for the bladder. No need for any special kind of syringe, easy to fill. Works a charm, nice even runs and flies awesome.
Red cap? Can you tell me more about this? Thanks, Tim
Andre
Riley did win the 68 Nats with a Vampire in Olathe. I dont recall who he flew or what airplane they used. But I was there.
It may be a bit before Riles can email anyone. He has had another stroke and isnt doing great. Time will tell how this will come out.
Use them the same as a pacifier or bladder. http://littleredcap.com/ (http://littleredcap.com/) They have less pressure and work great. Ridiculous cheap on Ebay. I keep several made up in my flight box.
Guess I will give them a try. D>K
Almost missed Bob's note on Riley Wooten stroke
Met him several times at Bobby Mears and a truly fine gentleman who was happy to listen to me prattle on about combat and ask him to sign a set of plans I had
Riley is in our family prayers
Wow! I will include him in my daily prayers! Tim
badbill ...... (or anyone who is familiar with "REDCAPS".) ..... I am looking for a replacement for the pacifier tanks of the 1960's which are increasingly hard to find and I see 'REDCAPS" mentioned above. Are these what you are talking about and if so how do you make them into a pressure tank. Is the final shape round like a pacifier or longer like a pen bladder or a surgical tubing tank? Sounds like a possible answer to what I am looking for .......... so.......is this the product and if so what do we need to know about their characteristics, life, etc. ...... https://www.ebay.com/p/Little-Red-Cap-Contractor-Pack-Caulk-Saving-Cap-Red-Pack-of-35/25011369909?iid=272279931859&_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D48419%26meid%3De2956f254d3e430895f5e8ccacb23588%26pid%3D100005%26rk%3D2%26rkt%3D12%26sd%3D361603202656%26itm%3D272279931859&_trksid=p2047675.c100005.m1851
Yes, That is them. They will hold a smidge over 2 OZ, and hold up well unless you overfill them. Final shape is round. I recently took out the Sneeker and flew it after it had been sitting for several months and the red cap in it worked fine, flew it six times that day. But I have to wonder why you think pacifiers are hard to find, I have bought binky's at Walmart not long ago, before I switched over to the Red Caps.
I have looked around (I guess in all the wrong places) lol and never found them. I did buy some pacifiers on eBay and they work great but wasn’t sure how long the pacifiers would be available and that is why the change to a hard tank on the Sneeker I am about to build. Now that I have options, I will stay with the bladder system. This is still new to me, especially combat planes, and I do appreciate all the advice and knowledge that you guys are giving me. Tim
I've used both little red caps and bladders. Bladders actually work a little bit better. Enough that I purchased hundreds of them just for modelers. I sell Nelson plugs on my site too if you need any.
https://www.ebay.com/itm/Combat-bladder-baby-pacifier-free-flight-pressure-fuel-system/172216355832?epid=1371059108&hash=item2818e50bf8:g:qfkAAOSwX~dWlFzN
Hi Bob,
didn't realize you were rx8guy.
Your ebay listing does not allow shipping to Canada. Any way around this?
I have an old Bosta someone gave me, it needs a pacifier setup so I can fly it.
We are all North Americans after all, a Mexican F2D pilot should know that ;)
Pat MacKenzie
Tim I will through in a half dozen red caps in the Sneeker Kit
and a few PIPETTES.... WallMart Gerber Pacifier bulbs are too strong IMO
Thanks Fred! I bought a used Fox 36XBB engine for the Sneeker today at my LHS. It has a fine needle thread on it and a smooth head. The insert has been removed but he said he has one if I want it. Compression is excellent too. Question, How many ounces will go into the pacifier or red cap? Thanks, Tim
Texas Timers (free flight supplies) sells a pressure reducing bladder fitting that makes needle setting a bit less sensitive (see "BLADDER FITTING" under the "Pressure Bladders" section, found in the left column):
http://www.texastimers.com
Thanks Chad. I took a pic of the engine I just bought, can anyone tell me anything about it? I heard it is a good engine for the Sneeker. I am especially curious about the smooth head. I was told this engine should run on a bladder system. Thanks, Tim
Tim:
That isn't a 36XBB. You have an infamous "bald head" Combat Special from 1974-75 or so. The 36X dies were irretrievably altered to make the bald head Combat Special, thus ending the production life of the 36X. The production tolerances were not good on the earlier bald heads. (It's a long and sordid story that I've told here elsewhere.) When you get a good one, they are very stout. Hopefully yours will serve you well.
Best of luck with it.
Andre
Hummmm, I didn’t realize the engine wasn’t very good and thought it was a BB. I may want to go and see what else is there.....Tim
Tim, Andre's comments are pretty much right on, but this motor had tons of power compared to the 36x. I had a Voodoo with an LS .36xbb and it was pretty fast. When the 'baldie' came out we wanted to compare. LS tuned the needle and launched. It was an easy 5 mph faster than before!! But..... the front of the crank snapped and the second shaft also snapped. These were from the very first batch. Another pal got one a little later and it is still running. So, I would give it a go. It will be thrilling!! TS
Well I guess I will give it a go! I really like the look of the smooth head, angled plug and especially the NVA! I honestly have a Fox 35 stunt on my Ringmaster and it has given me zero problems, all I did was to change the original needle valve to a Fox pointed one. I have read that a lot of people do not like Foxes. A question about the Baldie and fuel, what % oil should I use? My Fox likes 28%, the Tower 40 and my St G21 35( on my Sneeker) like 23% oil. Thanks for all the time and patience, Tim
I only use the Gerber 76099 pacifiers on all my Vintage combat engines, from my high nitro burning 128 mph Fox 36xbb power Super Satan, to my McCoy 35 Lightning bolt powered Hornet with the stock needle assy. I found the Pipettes bulbs or dropper bulbs to be weak and unreliable. I make my pacifiers by using a vacum hose connector inside of Dubro silicone fuel tubing, inside 1/2a combat bladder. Install that in the pacifier and wrap it with AWG24 coated wire between the vacuum tube barbs. The silicone fuel tubing is a lot easier to pinch but does not like to stay on the spray bar over 100 mph, so I use one inch of brass tubing to split the fuel line and use Dubro black neoprene at the spray bar. This also make it easier place to fill the bladder..
Al
Hi Bob,
Im sure I can. Order up and ill see what the shipping cost and let you know. If its too stupid we will just cancel the order
Pat MacKenzie
Either of those fuels should be fine. TS
Thanks. Well Bootlegger an I ran the 36X Combat Special yesterday on his test stand. Fuel was 10% nitro with a Castor/synthetic blend totaling 23% with a 10x5 prop. Very picky on the needle setting but finally got it to start. What a beast! 14,000 RPM! We ran it 4 times and called it quits. We did add a gasket to the head as it had none and changed the Phillips head screws to hex type screws before we started it. Does anyone have any information on this engine? 36X Combat Special baldie. I do not have an owners manual. Plan to run it with a 9x7, on a bladder in a Sneeker that I am about to build. Thanks, Tim
It might be easier to set the needle with a S-T type assembly. Probably the Smith/Nelson would be the best available now. Gsket is a good idea!!. TS
This engine was the predecessor of Fox's real schnuerle engines. He modified the 36x case to add a port on the front and back of the cylinder. After that engine he redesigned the case with the tall back plate for larger schnuerle porting.
Is there any way to determine if Baldie is an early or later version? I have one NIB, not planning to run it on anything more than Powermaster 10-22 with a 9-7 prop. (my days of BLAST with 8-8 prop are over, lol!)
Lyle:
I "think" I recall that the early ones didn't have a web in the exhaust, and later did?
Way too many decades have gone by for me to remember all the mfg'ing nuances "back then" when it was my daily job. Hopefully someone that's more knowledgeable than I will step in and give more accurate info. One thing that I vividly recall is the debacle for that engine that the "Second Operations" department created. Cost a guy his job... rightly so.
Andre
Andre, More of that story would be very interesting. No names needed. Thanks, TS
Pat MacKenzie
[/quote]
Ebay does ship to Rouge Park & Toledo.
I'm not a Fox guy, but maybe the "Baldies" had the same problem that I've heard the early Mk3s had. The Mk3 cranks would break because the hardened thrust washer had an incorrect radius on the back (rear) inside hole diameter. When a prop was tightened down it caused a stress riser on the crankshaft, which would eventually lead to failure.
The early, black shafts were bad. I had a good shaft, but mine cracked at the bottom of the front bearing housing.
I am not sure what shaft this one is? It does run very good and is very powerful!
I’d sell it to a Fox collector. Any value it has as an engine is temporary.
Yeah, but Howard, you were kinown to run 60 to 70% nitro. (as was written on your fuel jug in 1966 at the Glenview Nats......... "10% more nitro than you are running" ...... I peeked !) y1 H^^
C.T Shaefer
Hard to search for and I doubt Andre Ming has saved copies of all HIS very informative posts on all the sites
so some digging is needed... I have read with much interest his Musing of his time at Fox...lots of back stories of his interactions with duke
some is here on SH but a lot on RC Groups...not sure if any on RC Universe or Stuka Stunt
Tim, when we talked on the phone, I didn't realize that was the engine you meant. Trade that away for one that actually says combat special on the case. I think I sold mine, but I'll check. It could last you a while, but you could also catch the prop wrong landing and mess it up.
Chad is 100% correct on the MK III. While this topic isn't in regards to that engine, it certainly looks like the same drive washer on the "Baldie". This would be a 3 cog drive on the crank. I use a ball mill and radius the back edge of the hole enough so that it isn't resting on the radius of the crank. While the crank is intact now, that kind of stress over time on the crank will snap it right where it exits the case.It's done it to my MK III's. One thing I don't like in regards to a Red Cap is the size hole within it. You have to use a large piece of tubing inside of it, then neck it down once again for your fuel tubing. This is just asking for a leak.
No need for all that. I use the plugs from Texas Timers with no tubing at all inside the Red Cap and it works perfect. Regular tubing works fine to the engine.
Besides looking at the thrust washer and fixing the rear radius problem, there's not much to be done. The early shafts also had also had a hardening problem and would break across the port. Duke introduced the baldie at one NATS, I believe. The Mark III came out early the next spring, with an offer to accept the shiny case version in for trade. Most of them went back. If you got a good shaft they ran well and were lighter than the III.
But really, it's more valuable as a collectors item, or just to have, than to use it. The case can crack too. The 36X case just isn't strong enough to be reliable in a production engine that has a lot more horsepower.
I have already drilled the motor beams for this engine, will the 35x fit? I have another Sneeker with a ST 35 on it but the bolt patterns are different. Tim
Going on memory here:
As I recall, the Baldhead had the same bolt pattern as most of the Fox combat engines from the early 60's on. A 35X or 36X NB/BB should bolt up to your motor mount beams drilled for the Baldhead. I THINK.
Wow. Never thought some of my old Fox spec memories would get so fuzzy.
Andre
I was talking with Bootlegger earlier and the topic of wing tip weight came up. Has anyone put wing tip weights on their Sneekers? The plans do not show any or mention them. Thanks, Tim
That is exactly what Gil said. Just checking, Tim
