Speed,Combat,Scale,Racing => Combat => Topic started by: Howard Rush on June 21, 2010, 03:45:29 PM
Title: Nelson vs. G.21 Supertigre
Post by: Howard Rush on June 21, 2010, 03:45:29 PM
I just compared weight and fore-aft CG for the two.  The Nelson weighed 238 grams, the Supertigre 243.  Weights are approximate because configurations vary: my Nelson has a black intake doodad, for example.  The Nelson sticks out farther behind the CG, which will make mounting it on an old airplane interesting.
Title: Re: Nelson vs. G.21 Supertigre
Post by: Greg McCoy on June 21, 2010, 03:48:23 PM
I like where this is going.
Post by: Paul Smith on June 21, 2010, 04:59:00 PM
In my experience, when I upgraded from a ST G21/35 to a Fox Mark III, the plane went about 15 MPH faster and lived out its normal life.
When I upgraded from a Fox Mark VI to a Nelson, it went about 20 MPH faster and self-destructed in about 80 seconds.
Post by: Kim Mortimore on June 21, 2010, 07:40:34 PM
Two questions:  Will there be a video camera present to record your first flight, and will you be wearing your clown suit?
Post by: M Spencer on June 21, 2010, 09:15:38 PM
"lived out its normal life " ! ? ?        . . . yes ? .
Post by: phil c on June 22, 2010, 07:40:50 AM
If you can get ahold of one, the mag case version is a lot lighter- about 210 grams, with the plastic intake.
Don't chuck the plastic intake.  It cuts fuel consumption(keeps drops from spraying back out) and seems to increase horsepower a bit by smoothing the airflow into the engine.
Post by: Greg McCoy on June 22, 2010, 08:29:23 PM
Which magazine was the first publisher of the Nemesis plans, and are they still available?
Post by: Howard Rush on June 23, 2010, 12:38:01 AM
American Modeler, about 1972.  Maybe it was American Aircraft Modeler then.  I'll send you some plans if I have an extra set.  I just cut up the one set I know I had.  Email me your postal address.
Post by: Thomas Wilk on June 23, 2010, 06:35:03 AM
the Nemesis II
Nemesis II * 1972 AAM Aug p14 * span 39.00 * area   339.00 * power .35 * plan #   822 * designed by Rush, Howard M.
Tom Wilk  H^^  S?P
Post by: Gary James on June 23, 2010, 07:19:09 AM
Hey Howard, do you want me to make a CAD version of the Nemesis II plans like I did for the Bosta?  I also have an unopened M&P kit from which I should be able to make copies if needed.
Post by: Howard Rush on June 23, 2010, 12:41:26 PM
I did one.  I might tidy it up after the Nats.
