Speed,Combat,Scale,Racing => Combat => Topic started by: Steven Kientz on June 11, 2010, 02:20:27 PM
Title: Fox 36X caster %
Post by: Steven Kientz on June 11, 2010, 02:20:27 PM
I have a Fox 36X that I bought at a swap meet.I'd like to use it on a Super Satan once it is finished.I need some info on fuel. Should I run all castor or 50/50? I'm thinking 10-15% nitro. This will be an ocassional flyer, I'll use the Pyschos for tearing up the sky. I do have one other question; When using these new engines( os .25 Tt 36) for combat, are you setting them up for a solid 2 stroke or do you keep the 2/4 break. My OS35 fp launches rich, after 10 laps or so it goes somewhat lean and runs the tank out that way. I'm using a plasic tank with hardlines(no clunk). Doesn't give the REAL lean laps at the end, just quits.Am I correct in thinking a solid 2 stroke run needs a higher oil %? My current fuel is Byron 10% w/ 20% oil(traditional mix?). I'm considering some Brodak fuel( higher oil %) or might wait and see what is available at the Nats
Thanks.
Title: Re: Fox 36X caster %
Post by: john e. holliday on June 12, 2010, 09:34:49 AM
I will let the experts chime in on this.  I myself just try to run the old engines a little richer than normal.  I am putting a Super Tigre .35 on my Equalizer. H^^
Post by: Frank Imbriaco on June 12, 2010, 02:34:37 PM
I only tell you what we did in the 60s and 70s with these engines.  Back then, we used castor of at least 25%  content with much higher nitro content than you plan to use. They ran well on the hottest days and I never seized one up. The 36x, as you know, has ball bearings and I never had to replace them.
Fast forward 2008- I flew my  Larry Scarinzi hopped up 36xBB on my Sneeker for the first time since 1976. Yes, it required some afterun oil to free it up from the  dried varnish, but the engine ran great on a pacifier. After two flights, I  decided to let my engine guy look it over.
 After cleaning the interior varnish,  he was amazed at the condition of the internals. No rust or  wear  and great compression. All due, nodoubt,  to castor.
It's messy, smelly and not popular at any level (R/C or U/C) except with some Ukie flyers who swear it gives the the best protection.
Post by: Terrence Durrill on June 12, 2010, 03:05:49 PM
Hey Doc
            Which Super Tigre .35 are you using on the Equalizer...........the lighter .35C or the heavier, but meaner G-21 .35?  Although I have two G-21 and used them in competition, I found that the .35C was a pretty good engine.  At present, I have four .35C Tigres and tend to use them more for sport flying the old combat designs of the 1960's and 70's because I am getting too old and slow to keep up with the G-21's any more.  I've never tried that thing of legend, a Nelson .36!!!!!!!!!........TDurrill    #^   H^^
Post by: M Spencer on June 14, 2010, 12:56:41 AM
Found the C-35 was thirstyer than the 21/35 in a stunter, Same for Combat ?
Post by: john e. holliday on June 14, 2010, 10:29:16 AM
Terrence I think it is the old 35C.  Used it on tank pressure back in the day.  Now have an insert to run on suction. H^^
Post by: M Spencer on June 17, 2010, 05:06:43 AM
even the infernal Stalker engines are recomending 22 % , Syn. with 5 % or 1/2 castor . to taste.
Ya dina go lean on the Castor if theres heat about .
Post by: john e. holliday on June 17, 2010, 10:01:37 AM
Was working on the plane last night and looked at the Tigre.  My mistake as it is a G21-35.  jeh H^^
Post by: Terrence Durrill on June 17, 2010, 05:29:47 PM
Doc, speaking from experience, that old G-21 .35 Tigre will be plenty of power for that Equalizer.  You are going to get some really hair raising flights with the right tank, fuel and prop..........TDurrill   #^   #^   H^^
Post by: M Spencer on June 18, 2010, 08:16:51 AM
Na , tis going in a Folkerts .
Post by: john e. holliday on June 18, 2010, 08:45:21 AM
Matthew,  must be going racing as the Fox .36X's I had were some I used in combat.   H^^
Post by: M Spencer on June 18, 2010, 11:12:35 PM
Meant the ST .21/35 !  just a leg pull, though . allways thought a 21/29 RV on a 11 x 4 d do it !
Digressing further (a 21/40s NOT a fox 36 ) wottle it do with the 9mm  intake in something like a demon,
a ST 40 BB ?  (got two ) .
