Speed,Combat,Scale,Racing => Combat => Topic started by: RC Storick on March 18, 2018, 03:04:33 PM
Do the engines need to be tethered in slow combat? I have 4 slow combat and 2 fast combat models almost ready for Brodaks. The 2 fast combat models are tethered and I have one shutoff thanks to Paul. So I need to know the address of where to buy those and I will need to add tethers to the first 2 slow combat models I built if this is the case.
The tether is not a purchase item.
It's just a loop of wire (.027" leadout) wrapped around the engine and secured to the bellcrank.
If the plane is already built, you can get by with a loop around the pushrod.
This is an ancient rule dating back to when a wood engine mount failed and allowed a running engine to get away. The account of the incident is inscribed on a runestone.
I know a tether is not a purchase item. I wanted to know the guys address for the fuel shutoff. It's good to know about the pushrod trick. Thanks
How about some pics of your planes. Would love to see them.
They have been on past hangouts. I will see if I can take some pics
best I can do
I buy the shutoffs and other things from Yaro in Ontario.
yarikmln@yahoo.ca
Very nice Robert.
Actually: From the AMA rulebook
"The airplane shall have a restraining cable (minimum .027 stranded wire)
that fits snugly around the cylinder barrel/crankcase or may go through a
hole(s) drilled through the engine webs and attaches to the bell crank
mounting bolt."
FAI F2D requirements are similar but more specific about attachment
