Speed,Combat,Scale,Racing => Combat => Topic started by: Clifton Gregory on May 10, 2010, 03:16:27 AM
I was wondering what's the best tank to use in the Demom Combat Wing that will fit properly. I will be running a Super Tigre or Fox 35.
A pacifier or bladder would be you best bet.
The pacifier pod will not fit smoothly into the wing, but will protrude above and below it. This rig has won many national and world championships, despite the apparent issue of drag.
The surgical tubing bladder fits into the model better and will look more streamlined. However, the very high pressure makes this system tricky to handle and even top level competators often favor the lower pressure of a pacifier, despite the big bulge.
If you have ever built the original VooDoo there was a diagram of the metal tank that was in use at the time. Just a pickup line and overflow. The pressure line went to the overflow if you used pressure. I seen a lot of them flown on suction many times with Greenhead K&B, Johnson Sport or Fox Rocket. H^^
I'm going with a metal tank, I have Veco tanks NIB but when I shake each and ever one some black stuff that looks like pepper comes out of the tubes. All the Perfect tanks I have I don't have this problem with that. Of course the plans call for a Veco Bellcrank & Tank. So can anyone tell me the correct metal tank to use in this kit, thanks.
These things were usually flown with pacifiers or bladders, as Paul said. The tanks that people used before bladders universally took over were the Veco T-21 series. Whenever anybody uses a metal tank, he first disassembles it to clean it out, puts the plumbing in the right places, and replaces brass tubing with copper.
A good combat plane with a good engine running suction will starve the engine at every turn...and they're usually turning. Hence the pressure rigs, internal or external.
I just recently built the Black Hawk Demon. I was able to make a bladder compartment that fit within the wing. I made mine fit between the spars and it utilized the front portion of the leading edge. Paul recommended to make the bladder compartment stick up and out of the model. I highly recommend this as well. I used a Russian .15 combat engine to power mine. This allowed for a smaller bladder which unlike yourself will be using a larger engine. My bladder tube was made out of a paper towel tube using the front portion of the ribs as end caps. I made this go under the spars which was a bad idea. I overfilled it one day and the pressure broke the glue joints on the spars. This was easily fixable but lessons learned. This was a neat plane to build due to its simplicity and mine flies pretty fast. Ken
A bladder or pacifier always needs to be a loose fit within its compartment.
Otherwise the fuel cell will be distorted at the first part of the run creating FALSE PRESSURE. The false pressure subsides when some of the fuel is consumed, then the pressure drops and the engine goes over lean.
One final repitition of an ongoing theme:
If you don't know anything about crankcase pressure, or bladders, or pacifiers, you are better off learning how to run a pacifier. That's the shortest path to success.
A failed hard tank can ruin your whole plane. A failed pacifier is easily replaced.
A vienna sausage can may fit for a pacifier pod. Fill the opening with an epoxy coated balsa disk, make a hole in the side for the pacifier.
Here is the tank I made for the little Sneeker. There are only two lines. The vent/pressure line and fuel pick up. In the past the fuel pickup was on the bottom of the tank in the bigger planes. It is not uni-flo either. The tnk is thin enough to fit between the spars. H^^
Hi Clifton
Take the measurements of the fuel compartment then go to www.brodak.com and look for the appropriate size tank, they have lots of tanks I'm sure you can find the size you need.
