Speed,Combat,Scale,Racing => Combat => Topic started by: dave siegler on February 14, 2011, 03:12:47 PM
I would like to put together some foamies for 1/2a general screwing around. I don't want a $200 0.49. I would like to use a few Norvel big mig .061 The needle looks like it would not work with a bladder, even on suction it is coarse. I have heard that some guys allow plane bearing 061's in 1/2 a high performance combat. I was wondering what needle valve you would use to fit a Norvel or VA?
I tried a Norvel on a Yvenko, it was nuts tail heavy!! n~
I can agree with what you are describing.
Dave, if you are just "screwing around" with the Norvel big mig you should be able to get a decent run with the needle provided on bladder pressure. "Even on suction it is coarse"? I fly them all the time with suction , no problem with the coarse needle. On a flying platter with a Big Mig and a balloon tank set fairly rich for launch i can get a pretty good 2 4 break and do some taildraggin. I have two ame's and two big migs on combat planes with bladder pressure, they can be a litttle touchy, but quite useable! I find that if from time to time i blow out the spraybar with compressed air they will work fine. Might try different types of bladder material to get the right setup, some can create more pressure than others.
Dave, I have used with good success the needle spraybar assembly from the Cox production backplates. I've pressed the spraybar out of the plastic and soldered a piece of 3/32 tubing over the hole in the spraybar. Some of the older ones and a lot of the cars used these backplates. They had what I believe was the 125 thread per inch needles. I found a lot of these to be the red style backplates. Those needles are similar to the Kustom Kraftmanship needles used on the Tee Dee engines. I just file a little fish mouth on the tubing prior to soldering and be careful not to get solder in the hole. A little creativity is needed to attach to the plane but its effective and cheap. Dale Kirn used something like this on his 1/2 A speed planes that were running on bladder. I saw this idea used in 1980's Model Builder mag. I have even made a nylon insert that fits into the bathtub venturi hole of the Norvel case. Its drilled and tapped for a Tee Dee venturi which uses a fine threaded needle. The engine runs very well and starts with ease. Ken
