Speed,Combat,Scale,Racing => Combat => Topic started by: Motorman on November 12, 2014, 08:48:57 PM
What's the wing area and wing thickness on a modern 1/2a combat plane?
MM
Check out the Core House designs.
Well, according to the Yuvenko web site, their models have 940mm (37 inch) wingspan, and 270mm (10.6 inch) chord. But I think the chord number is suspect since the wing is very tapered.
http://yuvenko-f2d.com/index.php/airmodels/0-8cc-c-l-combat-1-2a.html
I'd suspect something like 250 sq inches wing area.
I can measure some models later tonight. I have a Viko 1/2a model, a GRS Barracuda 1/2a, and the Brodak Gladiator 1/2a at home.
I might also have info on the Sonic Chicken 1/2a at home, too. Buzz Wilson has done some write-ups for MACA news on the Sonic Chicken.
-Chris
Thanks Chris, I need to build a plane for my P-Zero. So, about 250 sq with 36" span but how thick?
Here's what I got:
Brodak Barracuda Viko
Wingspan 36 36 37
Chord at center 10 1/2 10 10 1/2
Chord at tip rib 5 5.75 4 3/4
Thickness at center 1 1 1/8 1 1/4
Thickness at tip rib 5/8 3/4 3/4
Area 279 283.5 282.125
(Area = ((Center Chord + Tip Cord)/2) * Wingspan
Hope that helps!
-Chris
That's interesting. With a light fuselage I could use a flying clown.
No doubt about the Clown. I have one with a TeeDee 049 and it goes fast. And I mean the Clown racing size Clown. It will really go with a modern Ukrainian 049.
You could also go with a Junior Flight Streak. It's wing is 230 sq inches, too. I think it is more "combatty".
-Chris
All of the 15-size planes (Sig Acromaster, Jr Flite Streak, Jr Ringmaster, Jr Lightning Streak, Whipsaw) would work - and actually be a bit on the small side - with a modern 049.
