  • July 29, 2021, 04:17:38 AM
Author Topic: WTB Techno Hobby Glow Plug Clip  (Read 732 times)
Offline Dave Rigotti
  • "Electric...The future of anytime stunt"
« on: June 06, 2021, 04:04:14 PM »
Anybody in the United States have a NIB Techno Hobby Glow Plug Clip they would like to sell?
I can PayPal.  Include shipping to 44026
Thanks!
« Last Edit: June 12, 2021, 01:32:23 PM by Dave Rigotti »
Dave Rigotti
AMA 66859
Chesterland, Ohio
Re: WTB Techno Hobby Glow Plug Clip
« Reply #1 on: June 12, 2021, 01:32:47 PM »
Still looking. Anybody?
Dave Rigotti
AMA 66859
Chesterland, Ohio
« Reply #2 on: June 14, 2021, 07:23:21 AM »
I have a COX clip. That is why I'm looking for the Techno clip.
Dave Rigotti
AMA 66859
Chesterland, Ohio
« Reply #3 on: June 15, 2021, 05:40:30 PM »
Update:
Sent PayPal (not friends and family) to member bmmerlord on the 7th for NIB clip. No replies or tracking number.  Just letting everyone know my experience with them.
Anyway....Still looking....
Dave Rigotti
AMA 66859
Chesterland, Ohio
Dave Rigotti
AMA 66859
Chesterland, Ohio
Online Craig Beswick
« Reply #5 on: June 16, 2021, 04:19:35 PM »
Dave,
the, "Seller", signed up to Stunthanger on the 6th of June. It would seem only to contact you!?
I strongly suggest, actually I assume you have already started the refund process. It takes a little time but you will get your money back.
I understand you want the product and it is all a pain in the backside. Sadly, part of buying on the internet.
Craig
AUS 87123
"The Ninja"
« Reply #6 on: June 16, 2021, 05:41:52 PM »
Craig,
Exactly!
Dave Rigotti
AMA 66859
Chesterland, Ohio
  • Millville NJ PDQ Flying Clown Country
« Reply #7 on: June 17, 2021, 12:04:07 PM »
I'm WELL AWARE!
I was looking for one stateside...
Good luck with that captn' btw I tried to order one and this is the response I got from Techno hobby:
"Unfortunately Glow Plug Clip is not available now and the nearest time.
Best regards, Oleksii".
So, I guess it's like many things in model aviation, it was made for a time and now it's gone.
Motorman 8)
Remove victim to fresh air
« Reply #8 on: June 17, 2021, 02:14:00 PM »
Thanks!
     I have been around this stuff for a LLLLOOOOOONG time, worked at a local hobby shop for 35 years, and seen tons and tons of people's old stuff and endless adds in magazines and have never seen anything like this. Looks like it is supposed to attach to a cable, like you could change styles of clips?/ What size engine were you planning on using this one, out of curiosity?  It looks like it's intended for 1/2A?/ I just grabbed a length of .047" music wire and with a small pair of round nose pliers I bent a reasonable facsimile of what I see in the picture with no size reference. Just need to wrap some copper wire around the main body of each part, solder a wire to each part, then epoxy them to some sort of insulator to separate them, and then put some layers of heat shrink tubing around the assembly. Only took me about 20 minutes to bend the parts and make them fit a Cox .049 glow head.
    Again, what engine or plug was this intended for??
« Reply #9 on: June 17, 2021, 02:31:13 PM »
Dan,
 It's to fit a Nelson Speed glow plug fitted to my Fox .35 stunt speed plane.
Thanks I have an alternate now.
Dave Rigotti
AMA 66859
Chesterland, Ohio
« Reply #10 on: June 17, 2021, 03:20:03 PM »
Dan,
     OK. Can I ask what you found? I have some Cox heads for Nelson plugs and will check this thing I bent up on those. I have some Norvel engines that have the ceramic cylinders and "normal" glow clips don't work well on those and will see if this thing fits those also.
« Reply #11 on: June 17, 2021, 05:56:00 PM »
I altered a COX 1/2A glow clip.  Clipped the small fingers about an 1/8" and then soldered some .008" tin plate to the "base" fingers to narrow the gap so she sits on top of the Nelson plug.
Dave Rigotti
AMA 66859
Chesterland, Ohio
Offline Guy Markham
« Reply #12 on: June 18, 2021, 08:50:11 PM »
There is a better clip available : from MECOA  (www.mecoa.com)  Part # 999-171. It is a Holland Hornet glow plug Clip. See pics
You only have to floss the teeth you want to keep!
« Reply #13 on: June 19, 2021, 03:05:31 AM »
Have you used the Holland Hornet clip with the Nelson glow plug?
Dave Rigotti
AMA 66859
Chesterland, Ohio
Offline Guy Markham
« Reply #14 on: June 19, 2021, 06:56:19 AM »
Yes, Works O.K. Best, Guy
