  • August 01, 2025, 04:13:11 AM
Author Topic: Please delete: WTB OS SF-S 46 Crank  (Read 1237 times)
Offline Peter in Fairfax, VA
« on: February 21, 2021, 12:07:51 PM »
So I have an OS SF that I'd like to adjust for stunt timing by installing a stunt crank (stamped SF-S).  Anyone have one for sale?  Also open to buying a whole motor.  My Pathfinder requires two ounces of nose weight, which I am thinking might as well translate to longer lines and a heavier motor than its existing OS LA 46.
thanks,
Peter
update:  Plan to use the stock crank, for now.
« Last Edit: February 23, 2021, 07:31:56 AM by Peter in Fairfax, VA »
Re: WTB OS SF-S 46 Crank
« Reply #1 on: February 21, 2021, 06:54:05 PM »
Mr Aero / Smith had em listed . https://stunthanger.com/smf/aero-products/
Incidently , most of the 15 mm & clone cranks interc hange,
So you could throw a thunder tiger 46 one in,for 20 mm stroke . if the flywheel clears the case , we willum check it . Hold your seats . Tomorrow all may well be revealed ! .
Theres also a 21 stroke 50 FSR crank that may well fit. Perhaps . the SF is 22 bore x 19.6 stroke, like the LA 46 .the 40 SF is the same stroke . FSR 45 crank stroke is 20 mm , ands a straight swap .
 :P ::) %^@
