  • August 02, 2025, 03:42:40 AM
Author Topic: WANTED: Brodak Needle Valve Assemblies, Needles, Proper O-Ring Size For .40s  (Read 1284 times)
    The Brodak web site show "Out Of Stock" on Needle Valve Assemblies and needles for the B-40, but I will call to verify tomorrow. If any of you electric guys that have sworn off engines have a couple of each laying around, let me know. Also if anyone knows what the proper size is for the venturi O-ring, I would like to know. Taking apart a used engine might bit yield good used parts or correct sizes. Just working on some previously abused engines.
   Thanks in advance!
« Last Edit: August 19, 2022, 03:11:19 PM by Dan McEntee »
Offline Bill Morell
Re: WANTED: Brodak Needle Valve Assemblies, Needles, Proper O-Ring Size
« Reply #1 on: August 19, 2022, 11:22:39 AM »
Try shtterman for the "O" rings or Jim Lee.
Bill Morell
Vietnam 72-73
« Reply #2 on: August 19, 2022, 02:47:26 PM »
For the O-ring you sorta' hafta' know which engine.
Offline Bill Morell
« Reply #3 on: August 19, 2022, 05:59:03 PM »
Sometimes you sorta hafta read the post. Says for Brodak B-40. Fairly clear.
Bill Morell
Vietnam 72-73
« Reply #4 on: August 19, 2022, 08:33:53 PM »
I guess you missed the edit he did after I posted. Anyway, the o-ring out of my B40 is black Buna-N, square in section and measures .042" thick, .395" ID, .525" OD. Probably supposed to be 1 x 10 x 13.5mm
Hope that helps,
Motorman 8)
« Reply #5 on: August 20, 2022, 07:12:43 AM »
Hope that helps,
Motorman 8)
     I guess you missed the part where I wasn't interested in a measurement from a used engine because they might not yield good parts or correct dimensions. O-rings tend to shrink and distort after being squished in place for any length of time.
Sorry I tried to help you.
