  • August 01, 2025, 07:34:16 PM
Author Topic: wanted  (Read 1878 times)
Offline Wayne Rice
wanted
« on: January 16, 2024, 07:25:07 AM »
spray bar and needle valve /venturi for a g21supertigre 46
Offline Doug Moisuk
Re: wanted
« Reply #1 on: January 16, 2024, 09:53:57 AM »
Randy Smith has the best needle valve assemblies, no air leaks. Not sure if he has ventures. Try Lee’s Machine shop for ventures.
Doug Moisuk
MAAC 3360L
Offline Wayne Rice
Re: wanted
« Reply #2 on: January 16, 2024, 11:44:38 AM »
Thank you for the great  info!
Offline Marty Hammersmith
Re: wanted
« Reply #3 on: January 16, 2024, 01:08:55 PM »
Jim Lee will set you up with both. There is also a guy named Bob on eBay who sells a lot of needle valve/venturi assemblies. His venturis are machined in Ukraine.
 The advantage of using Jim is that you can specify the venturi dimensions inside and out to suit your needs. He’s helped me convert several r/c engines to c/l.
Marty Hammersmith
AMA 6568
Offline Wayne Rice
Re: wanted
« Reply #4 on: January 16, 2024, 03:27:48 PM »
Thank you for all the help! would you have jim lees contact info ?
Offline Rusty
Re: wanted
« Reply #5 on: January 16, 2024, 03:29:59 PM »
