  • June 16, 2025, 12:45:59 PM
Author Topic: Wanted: 3-blade 12x6 CF props for electric  (Read 980 times)
Offline AMV
« on: September 07, 2022, 10:43:44 AM »
Tractor or pusher, doesn't matter. Where can I obtain a handful?
Cheers  H^^
-Andrey
Spice is the variety of life.
Offline Mike Alimov
Re: Wanted: 3-blade 12x6 CF props for electric
« Reply #1 on: September 07, 2022, 12:49:25 PM »
Do they have to be carbon fiber? Master Airscrew makes them in this size in both pusher and tractor versions; available immediately in unlimited quantities for about $10 each.
Offline AMV
« Reply #2 on: September 07, 2022, 02:01:12 PM »
Yes. I have the MAS ones; I'd like to try something lighter in that size.
Offline Fred Underwood
« Reply #3 on: September 07, 2022, 02:37:01 PM »
Xoar has them.  I didn't see weight, but the 2-blade electric is about 18 gms.
https://www.espritmodel.com/xoar-propellers-3blade-electric-pjie.aspx
The 12 x 6 was in stock.
Fred
352575
Offline Crist Rigotti
« Reply #4 on: September 07, 2022, 04:18:32 PM »
$52 each!
« Reply #5 on: September 07, 2022, 04:28:41 PM »
$52 each!
They are also wood, not CF, but fairly light.  At that price, I didn't suggest he get the " handful" that he mentioned :-).  Light 3 blade for electric in 12 x6 are not plentiful from what I could tell.  I also looked a while back.  There may be a European 12 x 6 CF prop, but I could not find it again.
Fred
352575
Offline AMV
« Reply #6 on: September 07, 2022, 05:55:35 PM »
$52 each!
Thanks for the link Fred!
That wood better be made of golden Beech... ;D but seriously it seems about par.. Igor's 12x5 CF is about $45, and a 13x6 CF 3-blade from Ukielands is $60.
p.s. My hands are small, so a handful is only about three  ;)
Offline Mike Alimov
« Reply #7 on: September 07, 2022, 06:01:58 PM »
Here's another approach: buy three 12-6 wood props and make two 3-blade props out of them. Badass shows those being available in both rotation directions at $8.49 a prop, which means it will be about $12 per each 3-blade prop. I can help you with that if interested. I used to make 3-blade combustion props this way; they all held just fine.
