  • July 17, 2025, 01:55:27 AM
Author Topic: Used 6S 2600Mah Li-Ion Battery Packs *****SOLD******  (Read 185 times)
Offline Crist Rigotti
« on: July 14, 2025, 08:07:01 AM »
Used, about 100 cycles, but in very good shape 6S 2600 Mah Li-on battery packs.  The Molicel batteries are spec'd at 500 cycles according to their spec sheet.  So these have a long way to go.  They have been well taken care of and always balanced charged.  They weigh about 310 grams each.  I soldered them together using 60 amp rated tin plated copper tabbing strips.  The output wires are high quality Castle Creations 13AWG.  NOT the typical 14AWG wire.
$27 each shipped CONUS.  Or all 4 for $100 shipped CONUS.  PayPal, Zelle, or check ok.
« Last Edit: Yesterday at 11:14:28 AM by Crist Rigotti »
Offline Jim Hoffman
Re: Used 6S 2600Mah Li-Ion Battery Packs
« Reply #1 on: July 14, 2025, 09:11:18 AM »
Could you share ........
Weight?
Who made them?
« Reply #2 on: July 14, 2025, 03:57:07 PM »
Weight?
Who made them?
310 grams.
I made them so they are high quality!  See above for additional remarks.
« Last Edit: July 14, 2025, 05:18:05 PM by Crist Rigotti »
« Reply #3 on: July 14, 2025, 06:51:03 PM »
310 grams.
High quality is an understatement - I have a set of his that have performed perfectly and all were within 1 gram of each other.
Offline Walter Hicks
« Reply #4 on: July 15, 2025, 01:57:11 PM »
Christ check your pm please.
