  • June 16, 2025, 12:46:01 PM
Author Topic: ISO McCoy needles  (Read 1605 times)
ISO McCoy needles
« on: October 27, 2022, 02:51:37 PM »
My flying buddy likes his McCoy RH’s. He needs two needles for 35’s.
I emailed Scott Reese as he use to be the McCoy go to guy but looks like he is not active here.
Anyone have a pair of needles?
Offline doug coursey
Re: ISO McCoy needles
« Reply #1 on: October 27, 2022, 03:08:09 PM »
I HAVE A GOOD COMPLETE ENGINE I WOULD LET GO CHEAP IM NOT GOING TO USE...DOUG
AMA 21449
« Reply #2 on: October 27, 2022, 05:40:20 PM »
Thanks Doug
He has several engines, problem is he is still landing inverted. 🤣
Offline Dave Moritz
« Reply #3 on: October 28, 2022, 10:54:12 AM »
I’ve an assembly from a McCoy 29 that looks like the same size as the 35 assembly. I’d be glad to mail it to him, gratis. Shoot me a PM.
Dave Mo
« Reply #4 on: October 28, 2022, 11:28:15 AM »
If you can't find a real McCoy try this.
https://www.mecoa.biz/shopexd.asp?id=4996
What I loved about the McCoy NVA was how it instantly told you if your prop was balanced. LL~
« Reply #5 on: October 28, 2022, 01:39:51 PM »
True dat.
« Reply #6 on: October 28, 2022, 01:40:53 PM »
Dave Mo
Thanks Dave.
I’ll let him know. Stay tuned.
Offline Ara Dedekian
  • Ara Dedekian
« Reply #7 on: October 28, 2022, 03:00:19 PM »
      If you're looking for authentic, try the needle that Mecoa sells for the Series 21. I believe the 19, 29 and 35 needles were the same.
      Ara
Online kenneth cook
« Reply #8 on: October 28, 2022, 06:33:54 PM »
            Paul, go to Shtterman on EBAY AKA the Control Line Store he offers Enya needle valve assemblies for about $14 which is quite a bargain considering the quality of them compared to what little is available. In my opinion the Enya needle is far superior to the Mccoy. However, there's always a however. If your friend is still coming in inverted, even the Enya is going to bend and it will bend the needle and the spraybar. So another option is the Super Tiger clones, they're darn near a direct fit but they will require a Perfect bellcrank fiber washer on each side to center it. You can figure out the proper needle setting and cut the needle where you can then remove the bluing and solder a washer to the top as a knob. This can keep your needle barely projecting out of the spraybar like the combat flyers do which will prevent the needle from getting wiped out.
