  • August 02, 2025, 03:37:37 AM
Author Topic: Head gaskets for McCoy 40 RH Stunt  (Read 1046 times)
Offline frank mccune
« on: June 14, 2021, 09:33:27 AM »
   Can you help?
    Tia,
    Frank
Offline BillP
Re: Head gaskets for McCoy 40 RH Stunt
« Reply #1 on: June 14, 2021, 12:13:16 PM »
shtterman on ebay has them.  NOS comes up on auction every now and then too. If it helps, the 29,35 & 40 Red Heads share the same backplate gasket. The cyl base and head gaskets are different. I think the 40 head and base gaskets are the same OUTSIDE diameter as the 35 gasket. You may be able to trim the INSIDE diameter on a 35 gasket to fit but it is really narrow and leaves little to zero room for error.
Bill P.
