  • August 01, 2025, 07:34:15 PM
Author Topic: LA-46 Nearly New  (Read 2546 times)
LA-46 Nearly New
« on: April 15, 2020, 01:21:41 PM »
Clean LA 46, blue, stock piston and liner.  Apparently never run, or maybe one short run. A few very slight rub marks on the case and head.  Belonged to Al Burkhart
Stock .265 venturi with OS Needle valve assembly.  Looked it over a bit more.  It has excellent compression.  It will pop over with enough snap from compression to  hurt you finger.  Very slow leak down if you hold it top dead center.
Email me with a fair price offer.  If you want I will include a very clean 3030 stock muffler and a metal(FP40) backplate.
Phil Cartier
« Last Edit: April 17, 2020, 05:53:30 PM by phil c »
Offline Chris Burkhardt
Re: LA-46 Nearly New
« Reply #1 on: November 08, 2020, 07:04:14 PM »
Is this still available?  I’d be interested in it with a muffler.
Offline Gerald Arana
« Reply #2 on: November 08, 2020, 07:55:29 PM »
Phil,
You are supposed to put a price on it in this section. You can always say "Best offer" in case your price is to high.
Good luck, Jerry
Offline Eric Krohn
« Reply #3 on: March 15, 2021, 09:46:38 AM »
is the os la 46 available? thank
