  • August 01, 2025, 04:13:10 AM
Author Topic: crankshaft for Fox .29R 'Bathtub'  (Read 1480 times)
Offline C.T. Schaefer
« on: March 23, 2021, 05:22:05 AM »
The crank I have is cracked so I need a good one to get this beast running.  Thanks!
Re: crankshaft for Fox .29R 'Bathtub'
« Reply #1 on: March 24, 2021, 04:59:30 AM »
starts at the front of port and goes almost all the way around HB~>.
Offline Steve_Pollock
« Reply #2 on: March 30, 2021, 01:45:55 PM »
The parts list for the 1956 Fox 29R "bathtub" engine is attached.  Unfortunately, the part number for the crankshaft is '29RC' and a Google search for that will get you every Fox 29 R/C engine ever made, but not a 29R crankshaft with that part number.  You will probably have to cannibalize a donor engine -- if you can find one.  Are you trying to make a running engine?  I also included the 29R engine test from the May'58 Aeromodeller FYI.
« Reply #3 on: April 01, 2021, 04:48:50 AM »
Thanks for the tips guys!  A casual search continues. I would love to run it but it also makes a great display item.
