  • July 03, 2025, 02:17:53 AM
Author Topic: Carburetor Wanted  (Read 1596 times)
Offline Mike Hazel
Carburetor Wanted
« on: March 23, 2022, 10:54:56 AM »
Wanted:   O.S. 4BK carburetor.   I am told that these came on various O.S. 40 size engines.
Re: Carburetor Wanted
« Reply #1 on: March 23, 2022, 12:04:25 PM »
I have several OS carbs but they don't have markings. Got a pic or dimensions?
Offline Mike Hazel
« Reply #2 on: March 23, 2022, 12:46:45 PM »
Do not have pic or dimensions.  The O.S. carbs I have do have a marking on them, but I guess there can be exceptions.
Dennis Leonhardi
« Reply #3 on: March 23, 2022, 03:11:28 PM »
OS lists the 48K as appropriate for the OS 40 FSR and the OS 40 FSR ABC ...
Offline Dennis Holler
« Reply #4 on: March 23, 2022, 03:41:00 PM »
I'll look, I may have a couple of grungy ones, If I do I'll PM you a picture of them.  They will be take offs from engine's I planned on stuffing a CL venturi on lol  You'd need to clean em and would need a new O ring  seal for it.
Edit:  No luck, have a handful of 4A's off of early 40H's and one 40D off an LA40.
« Last Edit: March 23, 2022, 04:11:39 PM by Dennis Holler »
I've started plenty...would be nice to finish something!!!
Offline Mike Hazel
« Reply #5 on: March 23, 2022, 05:05:26 PM »
OK, thanks for looking.
Offline bill bischoff
« Reply #6 on: March 23, 2022, 06:58:37 PM »
The 4BK came on the 40-45 FSR. They were/are very popular carbs in profile carrier. The 4D came on the 40 and 46SF. It had a .5mm bigger neck (.530"- 13.5 mm), and also a slightly bigger barrel bore. This is what we used when I was heavy into carrier. Unless you absolutely must have a 4BK, the 4D will give better performance and be easier to come by. I have a used 4D I can part with. Email me if interested.
Bill Bischoff
« Last Edit: March 23, 2022, 07:20:03 PM by bill bischoff »
« Reply #7 on: March 23, 2022, 08:39:14 PM »
Dang Bill, That makes me want to keep the 4D for carrier stuff lol.  What are the earlier 4A's good for?
« Reply #8 on: March 24, 2022, 06:07:29 PM »
I believe that the 4A came off the baffle-piston 40, and it is an air bleed carb. The 4D is a two-needle carb, which offers much better adjustment capability for smoother, more linear throttle response. I wouldn't use an air bleed carb unless the rules required it (like NW Sport 40 carrier). You mentioned that you had a 40D carb. That is a totally different carb than the 4D.
« Reply #9 on: March 24, 2022, 06:11:32 PM »
  I have a later model .46 FXI, I believe it is. HAs roundish head like LA.46. Carb on it says 40B I believe, is rear needle valve style. Looks like it's missing the low speed adjusting screw that is supposed to be in the middle of one side. If this would do you any good let me know. I had some other oddballlarge carbs but none with that lettering.
Offline Mike Hazel
« Reply #10 on: March 25, 2022, 09:44:19 AM »
OK, looks like Bill will be taking care of my need.  Thanks for the responses.
