  • June 14, 2025, 11:35:54 PM
Author Topic: WTB venturi and needle valve  (Read 6321 times)
Offline peter jurczyk
« on: August 17, 2024, 01:24:48 PM »
I am a little bit out of touch with flying model airplanes because I haven't picked up a handle since 2007. I am looking for a venturi and needle valve for an AP wasp o61 if anyone has got one or knows where I might find one, Maybe somebody still makes them? Thanks for any help PeteJ
Re: WTB venturi and needle valve
« Reply #1 on: August 17, 2024, 09:25:10 PM »
  Hi Peter;
    A couple of years ago, this subject came up in the 1/2A section. There was a guy that produced a venturi/adapter but I think he passed away. In one of the threads it was noted that he used the Cox TD-.049 venturi and spray bar set up. i got to looking into making something myself, and discovered that regular 1/4" brass tubing from K&S has an ID that is just right to run a 1/4"-32 trap into it and that is the threads that is on the bottom of the Cox TD venturi. I tapped the tubbing, cut it to length and JB-Welded it into the crank case of the Wasp engine and the venturi assembly attaches now just like the it does on the TD.049. Do a search on the 1/2A section using the Wasp .049 as a criteria and see what pops up. I haven't run mine yet, but others report that using the old adapter worked well and there may be other ways to mount something I don't remember. In talking with Jim Hoffman , he just locks the throttle in a certain position and flies them that way. This gives you the advantage of closing off the throat opening as desired if needed to get the run you want.
« Reply #2 on: August 18, 2024, 05:51:01 AM »
Thank you very much for that info and I am pretty sure i have some of that quarter inch stuff stashed in some boxes and will give that a try H^^
Offline 944_Jim
« Reply #3 on: August 18, 2024, 09:56:09 PM »
The trick is getting the TeeDee parts. Every time I look, one or more of the parts is/are unavailable.
I'm starting to think 3D print or machine a typical venturi and run a Cox reedie NVA through the case and venturi ala Medallion.
« Reply #4 on: August 19, 2024, 05:49:22 PM »
This place on ebay has a bit of the stuff needed and seem to be fair prices
https://www.ebay.com/str/exmodelengines?_trksid=p4429486.m3561.l170197
Offline 944_Jim
« Reply #5 on: August 19, 2024, 08:47:30 PM »
His name is Matt. I buy direct from him. He owns this site:
http://www.exmodelengines.com/home.php?cat=285
The link takes you directly to his TeeDee parts. Sadly, only the venturi is currently available.
The other guy is Bernie. Again, I buy direct sometimes. He owns this site:
https://coxengines.ca/front-end/
Bernie shows the needle valve body and venturi, but no needle valve.
One is left looking for the TeeDee needle valve.
I'm still thinking a custom venturi and Cox reedie NVA may be the fastest way to bypass the carb. I also took. A look at eBay and saw those guys are expecting over $100 per engine. For that much, I'd ring up Bernie for a Tee Dee II if he still has them in stock. He did a short run of them earlier this summer. I got one! A Norvel can land in your hand for less than the AP at this point..
« Reply #6 on: August 19, 2024, 09:06:06 PM »
I have already got two TDs and one AP one TD needs the rod reset but other than that I'm good to go
Thanks for the info too . I would rather buy direct to so thanks for the links ;)
« Reply #7 on: August 20, 2024, 05:16:30 PM »
Sent PMs to you Dan but not sure you got them? Pete
« Reply #8 on: August 20, 2024, 06:05:41 PM »
  Yeah Pete, I got the PM. Finally got a few pics taken and will send them tonight. Just been busy !!
