  • June 16, 2025, 12:13:27 PM
Author Topic: Brodak Blue Angel  (Read 6667 times)
Offline David Ruff
Brodak Blue Angel
« on: March 30, 2015, 06:38:11 PM »
Talk to me about the Blue Angel.  I see that Larry Scarinzi used the Fox .59 Stunt in that bird.  Anybody here built one; even more curious if anybody mounted the Fox .59 in it.
Retired Army
Offline Balsa Butcher
  • High Desert Flier
Re: Brodak Blue Angel
« Reply #1 on: April 02, 2015, 04:34:36 PM »
I have seen one fly and pitted for its pilot at VSC a few years ago. It is an excellent flying classic legal airplane. An LA-46 would be a good choice for power. Trike gear but the main gear is wide track fuselage mounted rather than wing. Works well and ideal if one is flying off of a rough field.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #2 on: April 02, 2015, 09:10:54 PM »
 Doesn't John Miller fly one?
« Reply #3 on: April 02, 2015, 09:57:07 PM »
  John Miller has an All American Eagle that is painted up like a Blue Angel, That may be what you are remembering.
Offline David Ruff
« Reply #4 on: April 03, 2015, 08:45:24 AM »
LA 46 or ST 51?  Leaning toward the ST 51.
Probably use the Fox .59 for OTS.
Retired Army
  • High Desert Flier
« Reply #5 on: April 03, 2015, 12:32:50 PM »
LA-46 would be a better choice  for this model.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #6 on: April 03, 2015, 03:46:53 PM »
I think Randy Cuberly had a Blue Angel at VSC.    Took picture of him and the plane to show Byron Meriwether years ago.    Come on Randy fess up.
« Reply #7 on: April 03, 2015, 05:11:23 PM »
 Ahh yes, that's the one I was thinking of, thanks Dan. D>K
Offline David Ruff
« Reply #8 on: April 10, 2015, 07:06:54 PM »
I'm thinking the NEW Enya SS45BBS Ring PL Pro would work here....
Retired Army
« Reply #9 on: April 16, 2015, 06:27:07 PM »
Or, a PA .40 UL with a pipe!  VD~ Steve
« Reply #10 on: May 02, 2015, 08:44:12 AM »
Hi David,
That is the engine I would use and prop it for the speed that you and the model like.
BIG Bear
RNMM/AMM
