  • June 26, 2025, 09:49:06 AM
Author Topic: Shoestring fix  (Read 2848 times)
Shoestring fix
« on: August 27, 2007, 09:57:06 AM »
I've been talking with Geoff Goodworth about "fixing" the original Carstens plan of Bill Simons' Shoestring. As Bob Hunt has noted here, the original had a Skylark wing (Foam Flite, I think). Anyway, Geoff has been working on a plan that (hopefully) reflects Bill's actual plane better than the Carstens plan. We've been trading emails and I've seen some of the CAD drawings. There are a couple of questions that have come up that only those that knew the original plane can really answer. Perhaps Bob Hunt will chime in with answers since it seems that he knows the most about this great design.
1) The Skylark wing has a somewhat narrower root chord than the wing drawn for the Carstens plan. Should the Skylark wing be aligned at the leading edge or the trailing edge on the original plan? In other words, using the Skylark wing, either the nose moment or the tail moment is going to be slightly longer since the chord on the Skylark wing is slightly narrower. Or once aligned, should the nose or tail moment be shortened to maintain the moment arms?
2) Should the flaps mirror the Carstens plan or the Skylark? The Skylark flaps are slightly narrower at the chord than the flaps published in the Carsten plan. Looking at a picture of the original plane (top view), it seems that the flap should more mirror the original Carstens plan, but this is a question.
3) Are there other areas of the Carstens plan that are not accurate? Based on my view of pictures I've seen of the original plane built by Bill Simons and looking at the Carsten plan, it seems that the fuselage is a bit narrower vertically in the Carstens plan than tha plane that Bill built. But that could just be an optical illusion.
Anyway, Geoff really loves this plane and wants to develop a plan that is the most accurate representation of the original possible. I told him that my experience with it is limited to the Flying Models plan and what I could glean from pictures. It would really help if folks that knew Bill and have seen the original plane could contribute some of their observations. The point here is to come up with the most accurate plan possible.
Thanks for any help.
Re: Shoestring fix
« Reply #1 on: August 27, 2007, 12:07:56 PM »
Hi Ty,
That could be. Be nice to hear from Hunt or others that had direct experience. I'm just rying to help Geoff out with the plan. If the Flying Models plan is correct, or what Bill wanted, then great. The job is done. If not, it would be nice to have an accurate plan.
Re: Shoestring fix
« Reply #2 on: August 28, 2007, 08:14:51 AM »
Geoff has been in contact with me, also.  He designed the remake of the Goldberg Shoestring for Brodak.  (I will get those scale Shoestring plans to you, Geoff! ;D )
Bobby is on his way to Muncie (there I guess today) so I don't know HOW soon he will be able to comment here.  He DID cut Bill's wing, though, and we all know (those that have been around since the rocks cooled) that the magazines were notorious for getting things wrong in their plans.  Just a problem of the day of a Draftsman drawing plans in one location while the plane/designer were often hundreds/thousands of miles away.  No computers and CAD back then! LOL!!
Gettin it right is a project that needs to be undertaken.  I have no real clue as to any errors in Eric's kit as it pertains to the original (is it Bill's plane?) but we all need to try and correct any of the Classic/OTS designs if we know an error does exist.  The Formula S *published* plans are a direct example of this.  Every effort was made to draw then correctly, but thorugh no fault of anyone, they had some listakes.  This HAS been corrected by Jim before he passed.
Re: Shoestring fix
« Reply #3 on: August 28, 2007, 10:27:57 PM »
Hi Bill,
Yea. I built the Flying Models version and I can tell you it had some problems. Like the wing didn't fit in the fuse cutout as drawn. That was fun. If Geoff is able to come up with a corrected version that is accurate, I'd sure think about building another one. It's just a cool plane.
Offline Geoff Goodworth
Re: Shoestring fix
« Reply #4 on: August 30, 2007, 05:14:13 AM »
Hi Bill
The RSM Shoestring kit is Bob Whitely's Shoestring 2000.  Pat Johnston drew the plan and it is slightly larger than the Simons model.
I started looking at the Simons model about the time I started working on the plan for the Goldberg version but I stopped when I discovered some significant discrepancies in the plan and the build article.
For example, the chord lengths for the airfoil sections both tip and root shown in the plan view and the fuselage profile are quite different.  Similarly, the Flying Models article quotes a span of 57".  The inboard wing panel is the only one shown on the plan and it measures 29".  The plan also says to build the outboard wing with one less rib and 2" shorter.
As a machine design engineer in a previous life, I have difficulty reconciling rib lengths that differ by 3/16" or more between the lines drawn for a plan view and those drawn as the airfoil sections to by used for construction or wings that finish up 1" shorter in total span than the magazine article quotes.  Too many discrepancies for this little black duck.   HB~>
Cheers, Geoff
And Bill, the plan is not a priority.  It's a drawing that this Shoestring tragic wants for reference and maybe to build one day.
So many aeroplanes, so little time.   y1
Geoff
Re: Shoestring fix
« Reply #5 on: August 30, 2007, 09:30:34 AM »
Hi Geoff,
I have started at my new school, and we are now underway.  Things are slowing down and I will be able to wrap my head around the *important* things soon!  LL~  y1
I built a Goldberg Shoestring in 1964 fo rmy first "big plane"!  I now have, thanks to John Tate, a Brodak kit which I will build before too long.   Gonna use a primo McCoy 35 Red Head! ;D
As to the Shoestring plans from Paul DelGatto (IIRC, they are the old Air Trails ones) I will get them copied and sent to you.  I *believe* the scale marked is 1 1/2"-1'
My *second* scale stunter project is a Cosmic Wind/Little Toni. !!   :o  #^  y1
(first one is a top secret, need to know only, ultra classified Sercurity Level 35 required, I would have to kill you if I told you, plane that has been drawn with the help of Ron "F-4 Guy" Burns!)  If you want to know, email me!  LL~
Bill <><
Re: Shoestring fix
« Reply #6 on: August 30, 2007, 10:03:20 AM »
Bill,
When are you going to finish that top secret, needs to know, classic plane?
Re: Shoestring fix
« Reply #7 on: August 30, 2007, 11:15:36 AM »
Bill,
It isn't legal for  Classic ( I don't think!), and it will be a WHILE!  LL~  Lots of "new to me" construction techniques, etc., and there are things that need to be finished BEFORE I start cutting wood on this one.  It is developed off of some R/C scale plans..........
Re: Shoestring fix
« Reply #8 on: August 30, 2007, 11:54:28 AM »
I thought you had a classic plane going? A somewhat unusual one.
Re: Shoestring fix
« Reply #9 on: September 01, 2007, 08:15:40 PM »
Yes, but it is the very early stages.  I need to finish up a few projects (for me and others) first.  It is a very early '60s design that has only been published as a very small three view, many, many years ago..  It will be published if it turns out good.  :o ;D
I am finishing up a PA ,60/piped size P-51B Paul Mantz #46 right now....... FINALLY!  I redrew Bobby Hunt's P-51D froma few years ago (Dan Banjock has been flying one) and I made it a "B" to give it a touch more scale look.
Aaron has a job now (Education!!) that gives him a LOT more time to build and fly.  He has been coming over to build and it has me pumped up again to get back into the shop and turn out a new plane.  He suggested today that I get the Mustang finished since I haven't built myself a new PAMPA plane in over 10 years!  I only have the fuselage turtle deck "blocks",and the flaps left to do.  Gonna mold the turtle deck, it's 2 1/2" tall!   :o  :o
Re: Shoestring fix
« Reply #10 on: September 01, 2007, 10:46:46 PM »
Bill,
How did you handle the pipe with the belly scoop?
Re: Shoestring fix
« Reply #11 on: September 02, 2007, 10:05:39 PM »
Bill,
It's really not a problem.  The exit is near the end of the scoop, sorta like where the cooling door lowered on the real one.  Dan Banjock's "Suzy Q" P-51D is the original drawing of the plane by Bob.  I just thought the "B" gives it more of a scale look in the fuselage area.  Got to make a mold now for the turtle deck.  Got the front block on it and will use sheet and corner fillers on most of the bottom.  A good find for me was a set of North American factory drawings of the "B" model!
