  • July 31, 2025, 07:26:41 AM
Author Topic: What plane for Veco 19BB  (Read 17974 times)
Offline Harry Rountree
  • HARRY ROUNREE
« on: November 22, 2022, 11:17:39 PM »
I have a Veco 19 Ball Bearing and need a plane for it using 52 ft lines.  What I see at Brodak I think is too small or too Big. Am I just not seeing one. Little help please. I have a Akro and Flite Streak Jr with .15s the .19 seemed to heavy for the Acro so I put a OS 15 on it. Would the 19 fly the Full size Flite Streak profile? Im Just a Sunday flier cant turn worth a darn... Harry
  • HARRY ROUNREE
Re: What plane for Veco 19BB
« Reply #1 on: November 22, 2022, 11:58:35 PM »
thanks  Ty Ill look into the Full Size FS. HR
Offline C.T. Schaefer
« Reply #2 on: November 23, 2022, 06:10:58 AM »
Another possibility is the Brodak Shark 402. It will handle the Veco very well.   Mine has an LA .25
Offline Ara Dedekian
  • Ara Dedekian
« Reply #3 on: November 23, 2022, 06:22:03 AM »
       Is your Akro a Sig Akromaster? I've been flying one for years with a Fox 19 plain bearing. I can fly  most pattern maneuvers with that combo on Spectra lines. I also had a full size Flight Streak with a McCoy 19 that worked well as a trainer/sport flyer. Your Veco should be a good match for either one.
       Ara
Offline MikeyPratt
« Reply #4 on: November 26, 2022, 03:02:42 PM »
Ara,
The Veco 19 BB is a great engine, it has lots of power and easy to run.  Anything that a .25 will fly I can handle with ease.  Lightly build is the key on Sig Twister or Banshee are really fun to fly and very competitive.  I had one of the first Veco 19 BB and put that into a Green Box Nobler, I won a bunch of contests with it, the prop I used was a 10 X 4 Tornado wood Plasticoat prop.  There are many props around now days so finding the best prop shouldn’t be hard.
Later,
Mikey
Offline George Fruhling
« Reply #5 on: December 03, 2022, 09:29:30 PM »
The full size Flite Streak will fly with the .19BB, as it is a strong engine for it's size and the Top Flite Streak  is not a heavy model. I have flown them with McCoy .19's (at sea level).
I wonder if a Flightstreak would be tail heavy with a .19.  I used a .35 or .36 Fox combat Special engine. It was quite nose heavy with a K&B 6.5 but very fast on 20% nitro!
