Classic Designs => Classic Planes => Topic started by: John Miller on March 04, 2009, 09:36:49 PM
Title: Torino on the gear, and almost ready for clear
Post by: John Miller on March 04, 2009, 09:36:49 PM
Well, here it is. The only color I've yet to apply is the wing lettering. I should have the paint masking graphics soon and then that will be done.
The color is Duplicolor auto touch up paints. I love the colors, and the ease of applying them. So far, all test show clear dope goes over it very nicely.
I'm needing a 2 inch Needle Nose spinner. I have a new in the box Veco cast version, but no adaptor to fit the Fox with it's 1/2 inch extension. So, for these pictures, I used an ugly yellow plastic spinner. It really needs the needle nose spinner, don't you agree?
Title: Re: Torino on the gear, and almost ready for clear
Post by: Mark Scarborough on March 04, 2009, 10:07:16 PM
Looks great John, are you coming to regionals this year? Looking forward to it
Post by: John Miller on March 04, 2009, 10:11:05 PM
Thanks Mark, Yes, I really want to make it to the Regionals this year. I'll look forward to seeing you there.
Post by: Tom Niebuhr on March 05, 2009, 08:39:45 AM
John.
Looks great.
What did you use for the fillets? Did you have Nitrate over the fillets? Did you use auto primer? Auto Clearcoat or dope?
Now all you have to do is apply several coats of clear, rub it out, bench trim, fly it, more trim, plus about 50 flights in the next week and a half for VSC... Phew!!!!!
Lots of luck to you at VSC! I will be thinking of you all that week.
Post by: John Miller on March 05, 2009, 12:08:28 PM
Thanks Tom
Yes, there's still a lot of work to be done. I'll be bringing it to VSC XXl, but the jury is still out regrading using it. I don't want to rush it, and chance losing it because of some item missed in the rush.
To answer your questions, I used a mixture of epoxy and micro balloons as described in Pete Petersons article in the latest Stunt News. I used 30 minute epoxy, thinned about 20% with alcohol with enough micro balloons mixed in to make a paste.
I already had all the clear fill coats, 4 coats of nitrate, with 4 coats of butyrate applied before installing the fillets. The last two coats of butyrate had Zinc stearate added. I used tape applied equidistant from the center of the corner to be filleted, to protect the finish from building up at the edges.
I applied them with my finger, then used a wettened round rod to even up the radius.
After about 1/2 hour, when they were starting to stiffen up, I ran my wetted finger to set a slight smooth surface to the fillets. Now remove the tape, and work down any edges.
Let them set over night, and you'll find they sand easily.
After sanding, I used a little spot glazing putty to put a finishing, sealing coat, over the fillets. The glazing putty will be dry enough to sand in an hour, after sanding, I applied one coat of butyrate, thinned 50%, and they were ready to finish.
I sprayed a light coat of duplicolor primer over the entire airframe, and sanded it smooth, removing most of it, the next day.
Next, a blocking coat of duplicolor silver. It covers well without having to be very thick and therefore heavy. It will be dry enough to sand in an hour or so. I sanded the silver with a very fine, 600 grit sanding foam backed pad. This doesnt remove much except it smooths the silver very nicely.
At that point it was ready to start the colors. The silver blocking coat helps brighten up the finish colors. I started with the metallic gold. Since I had made a full sized taping guide using the CAD file, it was easy to just apply the gold where it needed to be.
From there, it became an excersize in taping, and masking. For the second color, I just taped where the edges were defined to the gold.
As it sits, without the wing lettering, there are 4 colors. Except for the trim on the fuselage, all the colors were applied in one day. The duplicolor dries fast, and can accept tape in a few hours if you're careful.
I'm planning on using Certified non-taughtening dope for the clear coats. I'll use my airbrush to spray a couple of coats to the tape edges before sanding those edges down. It helps keep the edges sharply defined, and lets me smooth them out with less chance of sanding through one or both of the color coats.
Yep lots of work in store.
We'll miss you at VSC Tom.
Post by: Matt Colan on March 05, 2009, 01:37:05 PM
Looks Great John.  I like the DupliColor, I guess I'll have to try it sometime.  H^^
Post by: Dalton Hammett on March 05, 2009, 02:24:48 PM
Fantasic combination of colors - really a great effect
  Dalton H.
Post by: Dennis Adamisin on March 05, 2009, 08:08:49 PM
John:
The Torino looks fantastic.  Those colors will really pop out in the sun.  Way to go!   H^^  8)  CLP** HH%%
Post by: John Miller on March 06, 2009, 07:15:16 AM
Thank you guys. I hope you're right Dennis.  #^ y1
Post by: Randy Powell on March 06, 2009, 09:10:44 AM
John,
I'm telling you, get this plane to the Regionals and we can get a picture. Your gold, blue, silver, red and orange metallic plane and my three tone silver, bronze, candy red, orange, blue and purple metallic plane. Yikes!
Post by: John Miller on March 06, 2009, 09:23:37 AM
Randy, we have to be careful here. if we get these two planes too close together, we may cause blindness to the others in the area. I suggest we invest in some cool shades for ourselves, and the judges.  y1 #^ LL~ H^^
BTW, it was your colorful choices that influenced me on my color choices. I just cheated, and used an easier paint system. n~
Post by: Rod Claus on March 06, 2009, 10:12:22 AM
John,
You are a building animal!!Absolutly beautiful.....
See 'ya at VSC.
Post by: Matt Colan on March 06, 2009, 02:39:27 PM
John,
As I noted in a previous post, I am thinking about using duplicolor.  Is there anything I should do, or just spray it on like regular Brodak paint?
Post by: John Miller on March 06, 2009, 03:51:23 PM
John,
Hi Matt
Keep in mind that my experience so far involves using Butyrate dopes under and over the Duplicolor. So far no compatibility problems for me, but I don't know about other paints issues that may come up.
Duplicolor paints are Auto touch up paints, sold in rattle cans at the various auto parts stores, and sometimes in the auto sections of large mega box stores like WalMart.
There are 2 types sold, one is most desirable to us, laquer based, fast drying, and the other is enamel based. My experience is with the laquer based paint, though I suspect the enamel will work similar to Rustoleum paints. I prefer the laquer for it's fast drying and lighter weight. Having it compatible with dope is also a great help. As I've said above, I've used clear dope under and over it with out a problem so far.
Another positive to the duplicolor rattle cans is the noozle they use. It sprays a fan shape, rather than a circle. It makes for easier coverage for me.
The really neat colors are only available in the spray cans at the stores I buy it from. Speaking of the colors, they make colors to match most of the cars on the road, so the selection is super.
I can tell by your work with your Ares, that you have above average skills, and you care about the final project, so for you and others like you, I'll list out the procedure I used to this point.
I used Nitrate dope on the framework to seal up the wood before applying any coverinng. I had some problems later on in the finish, that might have been caused by the Nitrate, and I'm considering using Butyrate from the beginning in the future.
I applied Polyspan to the wing, using Nitrate thinner, ( because of the nitrate sealing coats on the wood ) with about 10% nitrate dope mixed in. It went pretty good, but I think I'll go back to using Balsa rite and my heat iron in the future. Ironing it on is much easier, accurate, and allows some flexibility with compound curves, a nemisis to some when it comes to Polyspan.
After all the wing panels were covered, I used my heat gun to shrink the Polyspan nice and tight. Be carefull to glue Polyspan tightly into place at first, because if you depend on shrinking out some baggy loose covering, you may have problems with holes where too much heat was applied. It's better to get the stuff tight right from the beginning.
I used Silkspan over the fuselage, flaps, stab, and elevators.
Next, I applied 4 coats of 50% thinned Nitrate. I would apply Butyrate if I were doing it again today. Why you may ask? simply that after the 4 coats of Nitrate were dried over night, when I put the first coat of butyrate on, the surface reacted with a waffle like pattern all over the open bays. No problem where I used silkspan over the wood.
Ensueing coats of butyrate only made the problem slightly better. The last two coats of butyrate had Zinc Stearate mixed in, and I really like how it works an helps level out a finish. Still, the open bays would look like "Alligator Skin" for houis after a coat was applied. I sanded out the Zinc coats, and it helped, but still bothered me, so I sprayed on a light coat of Duplicolor silver, and sanded it off with 600 wet or dry. This really showed the low spots over the open bays.
At this time, it installed the fillets. I used a mixture of 30 minute epoxy and micro balloons to make the fillets. I went into greater detail on the fillets, in a post above.
Next, I sprayed on a coat of Duplicolor primer. It's a easy sanding auto style primer. The next day, I sanded as much as possible off, then sprayed on a thin blocking coat of Duplicolor silver.
I found a really great foam backed sanding pad. It's about 600 grit, has a waffle like construction, and is very soft and fleixible. I used one to smooth down the silver paint surface.
From there on out, I used the blue flexible fine line style tape that picks up nicely, and limits any paint creep under the edges. I used a low tack masking tape, and aluminum foil to mask.
It went fairly fast due to the paints fast drying qualities. I like working with it, and think Duplicolor is worthy of consideration for your project. But, remember it's not really fuel proof. You'll need to coat every nich and cranny with clear dope before using it, Unless, of course, you're running an electric... :! H^^
Post by: John Miller on March 07, 2009, 06:36:50 PM
The graphics are on the plane. They look silver in the pic's, but they're really champaign pearl.
Tomorrow, the clear goes on. HH%% CLP** (PE**)
Post by: Randy Powell on March 07, 2009, 08:07:10 PM
John,
THAT"S AWESOME. This is going to be sweet.
Post by: Matt Colan on March 08, 2009, 06:54:46 AM
I think Randy and John may have started a new trend in finishes.  I have enough trouble with just three basic colors.  H^^ D>K y1
Ty, if you're having trouble with 3 basic colors, then how are you going to copy my Ares trim scheme???  And you should see the ideas that keep popping in my head for colors of the Oriental Plus.  I keep thinking of aqua colors for one idea, deep burgandy's and reds for another, and silver green or blue base with blue and black trim.
I really like the plane John, and yes you do need a needle nose for the front, in my opinion besides that other cheap plastic spinner  H^^\\
Post by: John Miller on March 08, 2009, 01:06:40 PM
Matt, Ty's an old Navy Chief. They always talk themselves down, so others don't know what they really can do. That way they can get others to do it for them. In the Navy, that's called leadership.... S?P LL~ LL~
Thanks for the kind comments on my plane. I now have a Needle Nose Spinner for it. My flying bud, Jim Rhoades took my Veco home and chucked it in his lathe. He gave it a neat light machine look, cleaned up some fits, and found me the right adaptor so I can use it. It's great to be in this hobby with friends like this all over the country. H^^
I'm applying the clear coats today. I'll post some finished pics in a few days.
Post by: John Miller on March 10, 2009, 07:44:57 PM
It's finished. I even got the obligatory "Cat" scan.  #^
As it sits, it's 45.5 oz's and should gas off some yet. The balance is within 1/4 inch of where I estimate it needs to be. That's a relief as with the long twin booms I was worrying about needing a lot of nose weight.
Now, I can clean up the shop, move the finishing stuff out of the living room, and start packing for Tucson. #^ #^ H^^
